Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator runs for about 10 min. then quits. i removed the wire that goes to the sensor.runs fine. only problem sensor was inserted through inside of motor during assembly .any ideas
  • 41 Answers
Sounds like a low oil sensor. Check engine oil level. If oil is at the corect level and problem continues replace sensor.
Posted on Oct 06, 2009
I have a 03 kia sorento that i just changed the timing belt and water pump on. It drove fine for about 10 mins but then stalled. After 15 mins it starts, runs for 10 mins, rough again and stalls out.
run fault codes
check for wiring on crank shaft position sensor or cam position sensor/s
it will be something that was affected by the belt replacement procedure
Feb 14, 2017 | Kia Cars & Trucks
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
Engine quit while running and now no spark.
Does the flywheel magnet still have a strong pull on it?
Mar 20, 2017 | Coleman Powermate Portable Generator...
97 GC 4.0 starts right up , runs fine for about 10 seconds then it goes into misfire mode. I have replaced the crank sensor, pickup coil in dist, 2 sets of wires ,2 sets of plugs, new dist cap , rotor...
Well, aside from the O2 sensors, the throttle position sensor and temp sensor, looks very much like you have a totally new system there.
I assume you got codes for all those item from a system scan?
I suggest that you "ring out" the wiring harness and check every fuse in the engine compartment and in the passenger compartment. If you have continuity and no cross over in the wiring, pretty good chance that the engine computer is bad.
One thing...your fuel pressure seems to be a bit high...I didn't look it up but I'd expect it to be around 35psi to possibly 40? Do the plugs come out clean or black?
Dec 07, 2010 | 1997 Jeep Grand Cherokee
I have kenmore model 790.75762001 turn on oven it goes on for 10 min then shuts off.then i have to reset again and wors fo a little then shuts off.
It is quite possibly the "sensor" which is defective and is sensing the temperature is too hot and shutting off as a safety feature. For about $70 and virtually 10 minutes work, you can replace it yourself. I have had great luck with "Appliance Zone" for parts. Be certain to take note of how the sensor is positioned on the back of the stove BEFORE you remove it. DO NOT put the connections back inside the insulation. You usually remove a couple of screws on the back to get to the sensor. If it appears to be charred or melted, pretty good indication it is the sensor.
Dec 21, 2009 | Kenmore 33169 Gas Single Oven
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
2146 runs fine for 10-15 mins then suddenly quits, gas supply fine, after sitting 2-3 hrs starts and repeats, ie 10-15 mins quits, suspect voltage regulator
coil may be breaking down or earthing out as vibration over time can wear out the insulation on the wire
Jul 21, 2009 | Garden
Coleman Powermate Premium Plus 6250W Portable Generator Logo
412 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
