Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
When i plug the usb in my computer it dosent see in
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 06, 2009
My Panasonic HM-TA1 pocket cam dosent read when i plug into the usb ..... i can hear the beep signal saying that its plugged in , but i cant see it on the computer ... does anyone know the problem ??
The camera should appear as 2 storage devices in 'my computer'. Are they visible?
Is it the original cable? If not, insert the camera direct into USB port.
Jul 04, 2011 | Panasonic HMTA1 Camcorder
My wireless keyboard and mouse has a computer connection of a USB plug and another plug that is round and green with multi pins in it. My new computer does not have a recepticle for the multi pin plug....
The round plug is for older computers that don't have USB. You don't need to concern yourself with it if you have USB. Just use the USB connection and everything will be fine.
Mar 06, 2011 | Logitech Wireless Access Duo Optical...
Could not open the flash drive. i think the drivers is not loading
when you plug the usb dose the computer recognize it and gives you a pop up new device found.
if yes then right click on the my computer icon go to manage and go to diskmanagement and see the drive and its there but dosent have a drive letter on it just right click and say change or add drive letter and it will apear on the my computer .
if it dosent recognze it when you connect theneither your usb port is disabled or the flash drive have an issu
to be sure try to plug this device in other computer if it works over there then its your usb port blocked by anti virus you are using .
or the port is not working properly.
thanks
Dec 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My computer is not recognizing the drive when I plug it in.
Hi did you try in other computer if yes and still didnt work do you listen any noise on the hard drive .
another thing to do to be sure that the usb ports are working fine in your computer its not been disabled bu bios or an antivirus please plug a flash drive or other hard drive in the computer and see if it gets recognized if yes then your system dosent have any issue .and check the hard drive if it dosent get recognized in the other computer also then may be the partitiontable is corrupt or your iomega hard drive case has problem.
To remove data from your hard drive in the worse case u need to remove the hard drive and plug it to the system directly and check
Thanks
Dec 04, 2010 | Iomega (33090) 250 GB Hard Drive
Why dosent my computer read my jensen mp3 player model smpv-4gbeb when i plug it into the usb port
I changed the usb connection. My camera usb connection fits my player, and it worked. For some reason the usb connection for the player didn't work.
Nov 08, 2010 | Jensen CD400M CD Player
Ipod will get power but computer dosent ever react when i use the coad to plug it into usb
Some computers don't put out enough juice to power by USB.  Thats why some external hard drives come with two USB cords.
Don't know what you mean by react.  Do you want the computer to smile at you or something?
Oct 25, 2009 | Apple iPod nano
When i plug my sandisk 2gb it dosent work!
Have you tried every USB port? Do any other things work on your USB ports? Is it USB 2.0 and your computer only does USB 1.0? Have you tried the sandisk in another computer? Does the USB port feel loose when the sandisk is inserted? Sounds like the sandisk may be bad.
Sep 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Simpletech 160mg pinifarina wont work
sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Microsoft Wireless Notebook Op. Mouse 3000 Dosent work.
try plugging the usb adapter into a different usb port of the computer and there must be a connect button on tat adapter..press the connect button on tat aadapter and then press the connect button on the mouse {after replacing the battery}.if it doesnt work on 1st go ,,try 2-3 times,,,and hey best of luck
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
My camera
Did you take the battery out while the camera what still transfering image to computer? If you did then you damaged your camera and will have to replace it.
Sep 09, 2008 | Casio Exilim EX-S500 Digital Camera
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
338 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
