Question about Whirlpool LER4634J Electric Dryer
Whirlpool comercial quality super capacity dryer does not heat up? I have looked at the heating element and it does not show any signs of damage or overheating. What else should I look for?
    President:
  • 1,304 Answers
Visual inspection can be decieving, if you have access to the heater ohm it out
check it for continuity,
its really the only test that is foolproof.
if that passes, i would make sure you have proper voltage at the posts.
Posted on Oct 06, 2009
How to change heating element for accudry
ear cover has to come off. Make sure the heating element is the culprit. Do a Continuity test across the Connector. If the Thermostat fails, you will not get heat either
Aug 09, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer shows f1
-Poosibly heater element are burn out.
Mai
Sep 22, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool ultimate care heavy duty super capacity dryer is not heating at all ,I tested the heating element for continuity , & have none , so this means the heating element is bad?
yes if you do not have continuity that meens the element is bad. just to be sure you may want to double check meter to make sure it is working properly, or check element for visual damage
May 12, 2011 | Whirlpool Dryers
Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
The dryer is not heating up. What should I be
Check element and thermostat, element reads about 32 ohms with multimeter if ok.
Apr 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Aug 09, 2009 | Dryers
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool LER4634J Electric Dryer Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
