Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire dryer Whenever i go to start my dryer instead of starting it just makes a clicking noise one time then it will flash the error code E9E. it is a Frigidaire Model #LEQ6000ESO
    Sergeant:
  • 272 Answers
It sounds like the programer on the drying side has had its day
Posted on Jan 05, 2008
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
Error code E9 on model #FASE7073NA
Hello Eric, this is Z I am happy to assist you!
I see that you are having trouble with your Frigidaire dryer (FASE7073NA) and that you are receiving an error code E9. However, is it possible that the code is missing characters? I show that E9 is an invalid error code. Could it possibly be showing E9B or E9E? Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
In the meantime, you may try resetting your dryer by disconnecting the power from it for up to ten minutes. You can do this by flipping the circuit breaker off and back. This often clears most false error codes. Hope this helps!
Aug 16, 2014 | Frigidaire Dryers
Frigidaire dryer error code e9e
Hello zabbster - Typically E9E means that there is an issue with the control board receiving low or intermittent voltage and you would need to contact a professional to verify the house wiring and confirm the power supply.
Sep 25, 2012 | Frigidaire Dryers
I HAVE A FRIGIDAIRE DRYER MODEL LEQ2152EE0 IT WAS WORKING ONE NIGHT AND WENT TO USE IT THE NEXT DAY WHEN I PUSH START IT MAKES A FEW SOUND FROM THE CONTROL BOARD AND THEN FLASHES E9E ON THE DISPLAY ANY...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Dryers
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
DR code on display
When I push the start button on my Fridgedare dryer model
gleq2152es it makes a click and E9E appears on the display
sceen.
Mar 15, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I keep getting a E9E error code on my Fridgidaire gas dryer. It starts, then stops and flashes the code
this is a line voltage error code press the cancel button for three seconds check you power and make sure the power supplied is correct.
Sep 12, 2009 | Frigidaire Dryers
Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Jun 09, 2009 | Frigidaire Dryers
My affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I get an E9E fault code on my two year old Frigidaire front loading dryer.
Sep 08, 2008 | Frigidaire Dryers
Frigidaire GLTF2940ES Front Load Washer Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
