Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag washer goes out of balance with any size load.noticed leaky shock on one side did all service checks all ok,add some clothing and it starts to rock
  • 335 Answers
This is common problem with the FAV6800AW and FVA9800AW.
See this post for a fix and if you can DIY you will save some $.
I will try to help you through the issue. If you call in a repair service you are looking at $300 - $350 for clutch repacement.
Will your FAV6800A shut down with unbalance errors such as dc or UC?
What is the leaky sock, is that from water around the base of the machine?
Rich
Posted on Oct 06, 2009
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
When spinning, Out of balance message occurs, then the machine starts to add water to get the load out of balance. It will put additional time on the wash cycle. It will drain and try to spin again. Then...
it could be weak shocks for the drum or the springs. you can also overload the washer. there should be a gap in filling washer with clothes around 5-to 6 cm's on the drum ring this gives space for movement and balancing. the washer can also become out of balance if the bearing is damaged, if you can lift the drum from the bottom of the ring and it moves up and down by few millimeters and feels lose then its usually a sign the bearing is weak. this can make the display say there is a problem with balance. 6kg or 7kg is the weight of the clothes and water not the clothes. over loading the washer damages the bearings and put more pressure on the shocks and springs.
Jul 03, 2017 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washer was over loaded came and shut it off and removed clothes to balance it out now it will do nothing but add a little water than stop no draining spining nothing
Have you tried balancing your washer? You have four adjustable feet under your washer. They are located on each corner of the bottom of your washer. They are only bolt threads. If you have overloaded your washer to which it is off set, you can adjust the feet to balance the washer. Be sure to unplug the washer first. Make sure you are clear of any electrical shock. Safety first!
Hunnybunny11
Jan 23, 2010 | Maytag MTW5600TQ Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Jan 27, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
MAYTAG MAH5500BWW Fails to spin properly clothes wet
I replaced the motor and circuit board but that did not fix it. I changed the out of balance switch and the shock absorbers or snubbers. I think the ultamate fix was the snubbers. it has worked great since. They wear out like your car shock absorbers allowing the drum to shake too much triggering the out of balance switch to stop and restart the spin.
Oct 22, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washing machine
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
May 09, 2007 | Whirlpool LSN2000LW Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
