Question about Canon PowerShot A1100 IS Digital Camera
How do you take black and white pictures instead of color? I don't want to wait until I develop it and change it then as the quality isn't as good.
  • 2,005 Answers
Press the function button, then scroll down to the "My Colors" icon (it will show OFF initially). Now scroll over to the BW icon and press the function button again. To return to normal shooting, do the same thing but select OFF.
Posted on Oct 06, 2009
Are the same chemicals used to develop color pictures as black and whites?
They are very similar but the black and white process uses developer, stop bath, fixer and water while the color process uses developer, bleach, fixer and stabilizer.process for black and white process for color
Aug 19, 2013 | Photography
Poor viewing quality
By poor color quality, do you mean that if you turn the color control all the way down, the black and white picture is more like black and red, green or blue - or do you have a good black and white image? If the B&W image is good, and the TV is an old (8+ years) one, maybe the mirror inside the set needs a good cleaning - especially if there are smokers in the room. If you have a B&W picture that is tinted, then you may have to go into a service menu to adjust it back to a better picture. Hard to guess the problem without more specific description of symptoms.
Jul 17, 2012 | JVC HD-56G787 Television
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
I have a HP Deskjet D4260 and when i print something using HP Deskjet D4200 series its black and white. I need the pictures to be in color
U must be using HP74, 75 cartridge for your printer.
There are few reasons you are getting black and white (gray)...for printing job.
1. No color ink.
- If you are out of color ink.. that's what it happens.
- check your ink level through control panel.
2. Printer set up. (I think this is pretty much the reason you are not getting color)
- First, check your printer setting.
If they are on gray scale mode, pls chang to color.
How? when you click the print (through file manu), there are option for control panel on your screen. Click that option and will see some detail option you can choose from size, print quality.
Among the print quality option, pls choose, color mode instead of gray mode. That's it.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Deskjet D4260 Printer
Two weeks back change Developer powder and Toner powder. Now printing quality is dull means printing is light. Please give me a solution
Ensure optics are clean and the drum isn't worn. You can try changing F6-21 towards the + side. This will boost your toner concentration.
Mar 22, 2011 | Panasonic DP-8020E Black and White Copier
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Canon PowerShot A1100 IS Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
