Question about Dewalt DC727VA Heavy Duty 3/8 Inch 12 Volt Ni Cad Cordless Drill/Driver Kit With Vehicle Charger
The fuse is blown in the charger. I want to replace it. 4A 125V
  • 2,176 Answers
Usually when the fuse blows in the charger there is some other malfunction there in the board. The charger for your tool is listed as obsolete to contact the service center, and in doing so ask them for the proper fuse, or replacement charger.
Posted on Oct 06, 2009
I have a Rascal 240. The battery charger has blown the internal fuse. It is a GMA but I do not know the proper ampherage to use. The fuse in it was repalced by the person who sold it to me and I
The charger puts out 24VDC@4A. Typically my charger [off a Rascal 600t] will charge at 3.5A. It seems that the industry standard is to multiply the amperage by 135% providing that your using the proper gage wire and the temperature is nominal. 3.5A x 1.35 = 4.73 or 5A. So i think a 5A fuse will do it for you
Jul 16, 2012 | Electric Mobility Mobility Electric Power...
Had a blown fuse on main board 125V 4A replaced and indicator came on green light flahes twice and goes off
Something else went when the fuse blew---voltage checks are needed and someone needs to check for shorts on the set to ground.
Apr 02, 2012 | Televison & Video
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
- fuse: 250V 4A
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Sep 12, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Blown in line fuse in the subwoofer box for a Bose speaker
Radio Shack. Ask at the desk, it may be order only part. Parts Express (online) has a great variety as well.
Dec 26, 2008 | Bose (321GS) System
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
Sanyo tv blows fuse when you turn it on
u have a short in the power supply section
Oct 24, 2007 | RCA F27242GY 27" TV
Dewalt DC727VA Heavy Duty 3/8 Inch 12 Volt Ni Cad Cordless Drill/Driver Kit With Vehicle Charger Logo
361 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
