Question about Lexmark C533DN InkJet Printer
How do I open the printer to change the cartridge ?
When I open the printer to change the cartridge, the wrong cartridge is in the opening
There is a "change ink" in your menu settings that will bring the printer head to the correct position for swapping cartridges.
Jul 17, 2014 | Konica Minolta magicolor 1690MF All-In-One...
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
How to change the inkjets
  1. Open the top panel of your inkjet printer. You should be able to access the ink cartridges once the top is open. Some printers will reposition the cartridge carriage to provide you better access.
  2. 2
    Remove the old cartridge from the carriage. Depending on the printer, you may need to press down on the cartridge and then pull outward to remove it. Other printers may require you to lift the cartridge out of the printer.
  3. 3
    Unpackage the new replacement cartridge completely. New cartridges will often include plastic strips and protective packaging that must be removed before you can insert the cartridge into the printer.
  4. 4
    Insert the new cartridge into the printer. This will be the reverse of removing the old cartridge.
  5. 5
    Close the top panel of your inkjet printer and allow the printer to detect the new cartridge. You should now be able to print using your newly changed inkjet cartridge.
Jan 02, 2011 | Canon Office Equipment & Supplies
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
Change cartridge on epson cx5500
Please try their website and search for the manual.
Sep 27, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Out of ink. Can't get cartridge to stop in middle to change
hi turn off the printer open lid move cartridge carrier to the middle, this should allow you to change the cartridge, then close the lid and turn on printer this should reset carrier to home position.
Jan 15, 2009 | HP DeskJet 810c InkJet Printer
How do I access the ink cartridge to change it?
Open the front of the printer, cartritge should locate on its own to a position directly in front of you,printer must be switched on.When carriage stops plase your finger on top of the cartridge and press down,firmly,and pull towards you.it is easy!
Good Luck.
Jan 02, 2009 | HP PhotoSmart C4180 All-in-One Color...
Please tell me how to change H.P printer 1020
Its very easy.
Open the printer. There is a certain place to put your finger so that you can open the printer to see the cartridge. It is next to the page holder, where the paper ends its roadwhen you print. After opening you can see the toner cartridge in the printer. Gently take it out. It has a ledge for helping you do that.
Open the new toner cartridge. Remove the rite seal holding the cartridge in a horizontal position. take it out all the way.
DO NOT TOUCH THE GREEN CYLENDER!!!!!
Holding the cartridge in a way that you can read the label put it on the printer until it goes all the way and in a way it stucks.
You re all done!
Dec 03, 2008 | HP LaserJet 1020 Printer
Changing ink for X1290
The printer needs to be on in order to change the cartridges. When you open the lid the cartridges should move into view.
Jan 15, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark C533DN InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
