Question about Locks & Locksmithing
I attempted to re key my lock now no key works. how can i fix this problem
  • magicklub May 11, 2010
    You need to be more specific. The problem is you've put the lock together incorrectly, but there's a thousand ways to do it wrong, and each mistake has an individual repair process. As much information as possible is needed to help you fix this.
  • Tim Carter
    Tim Carter May 11, 2010
    what kind of lock is it?
    Novelist:
  • 160 Answers
Try this ... Take a clear bag that you can get both hands in and still work. Take just your lock (not the whole door handle) and a screw driver into the bag and remove the the cover plate that keeps the springs in place ( being careful not to damage it ) it will slide off or will pop off. The bag catches all the springs and pins that will fly. Just dump in to the bag.
Now just re key and replace the top pins, springs and cover plate.
I hope this Helps,
RSMITH972278
Posted on Oct 13, 2009
The key wont turn in the door lock of my 2004 Ford Escape and the electronic locking mechanism doesn't work unless the key is in the ignitionl. How can I get into my car?
It's not going to seem very helpful, but the only way that you'll be able to take care of this is to manipulate the lock from the inside. This is, of course, assuming your keys are stuck inside your car. If not, attempt unlocking the door by physically using your keys.
If your keys are locked in your vehicle, use the AAA wedge on the door and attempt to retrieve the keys -- they physically will be able to manipulate the lock. If the keys are gone, you could attempt wedging the door open and using a metal or plastic bar or plate to bypass the lock on the door itself (passing it between the door closing mechanism and the frame of the vehicle). If you're desperate, and don't have the keys anyways, it may just be time to break a window and do things the old fashioned way.
Aug 05, 2015 | 2004 Ford Escape
How to fix samsung dous gt-s6102 lock password
Just do hard reset but it will delete all ur data in phone follow the step* Switch Off Your Device
* Take Out Your Sim And Memmory Card
* Press And Hold Volume Up Key + Home Key + Then Power On Your Phone
* Hold Pressing Keys Untill The Second Logo Appears
* When Scond Logo . Release All Keys
* Then You Will Get Factory Reset Menu
* Select Wipe Data/ Factory Reset Option . Scroll Using Volume Key . Then Confirm
* By Select Yes Delete All User Data. Using Volume Down Key . Confirm It
* Wait Some Seconds. Then Select Reboot System Now Option And Confirm
* Now Your Phone Will Restarted. After Completing The Hard Reset Prosses
* Done ! Thank u
Feb 03, 2015 | Samsung Cell Phones
04 tahoe liftgate will not lock
Make sure key is in the center locking position when removed. May have bad lock mechanism or lock mechanism was jammed shutt befor closing. You can take a screwdriver and pry out the lock latch while turning mechanism with key. Mechanism should pop open and lock should work. Do you have power locks? have someone work the switch as you attempt to free up mechanism with screwdriver.
Jan 19, 2013 | 2006 Chevrolet Tahoe
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
I have a 99 voyager and the ignition will not turn how do I remove it
Here's a copy of a service bulletin on your problem.
I'll bet the dealer says $300 for parts and 2 hrs labor.:screwy:
Ignition Key - Will Not Turn And/Or Cannot Be Removed
NUMBER: 23-23-00
GROUP: Body
DATE: JUNE 30, 2000
SUBJECT:
Ignition Key Will Not Turn And/Or Cannot Be Removed
MODELS:
1997 - 2000 (NS) Town & Country/Caravan/Voyager
OVERVIEW:
This bulletin involves performing one or any combination of the following procedures; cutting a new ignition key, and/or adjusting transmission shifter cable, and/or replacing the ignition lock cylinder and/or replacing the ignition lock housing and switch assembly.
SYMPTOM/CONDITION:
1. Cannot turn the ignition key when attempting to start vehicle, this condition may be intermittent.
2. Unable to remove the ignition key from the lock cylinder.
PARTS REQUIRED:
AR(1)04778115 Key
AR(1)05003843AB Cylinder, Ignition Lock
AR(1)04690523 Assembly, Ignition Switch and Lock Housing
EQUIPMENT POSSIBLY REQUIRED:
Key Cutter such as Pentastar Service Equipment (PSE) IL-MK1-P2627 or
IL-ECM-100
T-27 Torx Bit
T-25 Torx Bit
T-10 Tamper Resistant Torx Bit
SR-706059 Lock Cylinder Build Kit, Pentastar Service Equipment (PSE)
DIAGNOSIS/REPAIR PROCEDURE:
DOES NOT REQUIRE HOISTS OR OTHER FULL SERVICE FACILITY SPECIAL EQUIPMENT. THIS REPAIR IS COMPATIBLE WITH DAIMLERCHRYSLERS MOBILE SERVICE PROGRAM.
SYMPTOM/CONDITION ONE
1. Ensure the steering wheel is centered and the vehicle is positioned on a level surface.
2. Disconnect the negative battery cable.
3. Insert ignition key into the ignition lock cylinder and attempt to rotate the key to the start position and then the accessory position.
4. If the key does not turn, remove the key from the lock cylinder and rotate it 180°. Reinsert the key into the lock cylinder and attempt to rotate the key. If the key does not turn skip to step 14. If the key does turn make a new key.
NOTE: USE THE KEY CODE ON THE VEHICLE INVOICE TO CORRECTLY CUT THE NEW KEY. KEY CODES ARE ALSO AVAILABLE USING THE D.I.A.L. SYSTEM, MAIN MENU OPTION 13. DO NOT USE A KEY DUPLICATOR TO MAKE THE NEW KEY.
5. Insert the new ignition key into the ignition lock cylinder and attempt to rotate the key to the start position and then the accessory position.
6. If the key turns, remove the key from the lock cylinder and turn it over 180°and reinsert the key into the lock cylinder. Attempt to rotate the key.
7. If the key turns, repeat steps 5 and 6 ten times. If the key continues to rotate smoothly the repair is complete. If the key fails to turn smoothly at each rotation attempt, continue to step 8.
8. Remove the ignition lock cylinder using the procedure outlined on page 8D-29 of the 2000 Town & Country, Caravan and Voyager Service Manual (Publication No. 81-370-0005). DO NOT ATTEMPT TO DISASSEMBLE THE Lock CYLINDER.
9. Build a new lock cylinder to the key code on the vehicle invoice, using the instructions in the Pentastar Service Equipment SR-706059 Lock Cylinder Build Kit.
10. Install the new ignition lock cylinder using the procedure outlined on page 8D-29 of the 2000 Town & Country, Caravan and Voyager Service Manual (Publication No. 81-370-0005).
11. Insert the new ignition key into the new ignition lock cylinder and attempt to rotate the key to the start position and then the accessory position.
12. If the key turns, remove the key from the lock cylinder and turn it over 180°and reinsert the key into the lock cylinder. Attempt to rotate the key.
13. If the key turns, repeat steps 11 and 12 ten times. If the key continues to rotate smoothly the repair is complete. If the key fails to turn smoothly at each rotation attempt, continue to step 14.
14. Remove the ignition lock housing and ignition switch as an assembly using the procedure outlined beginning on page 19-47 of the 2000 Town & Country, Caravan and Voyager Service Manual (Publication No. 81-370-0005).
NOTE: SKIP STEPS 13 AND 14 OF THE SERVICE MANUAL REMOVAL PROCEDURE SO THE IGNITION LOCK HOUSING AND IGNITION SWITCH ARE REMOVED AS AN ASSEMBLY.
15. Install a new ignition lock housing and ignition switch assembly, p/n 04690523, using the procedure outlined beginning on page 19-49 of the 2000 Town & Country, Caravan and Voyager Service Manual (Publication No. 81-370-0005).
NOTE: PRIOR TO PERFORMING STEP 2 OF THE SERVICE MANUAL LOCK HOUSING INSTALLATION PROCEDURE, INSTALL THEN REMOVE THE TWO LOCK CYLINDER HOUSING MOUNTING SCREWS INTO THE LOCK HOUSING MOUNTING HOLES TO CREATE THE THREADS IN THE HOLES.FAILURE TO CREATE THE MOUNTING HOLE THREADS PRIOR TO INSTALLATION TO THE STEERING COLUMN MAY CAUSE MISALIGNMENT OF THE LOCK HOUSING TO STEERING COLUMN AND DAMAGE BINDING OF STEERING COLUMN MAY RESULT.
STEPS 5 AND 6 OF THE SERVICE MANUAL INSTALLATION PROCEDURE FOR THE LOCK HOUSING ARE NOT NECESSARY FOR THIS TSB PROCEDURE.
WHEN PERFORMING STEP 9 OF THE SERVICE MANUAL PROCEDURE USE THE NEW LOCK CYLINDER THAT WAS BUILT IN STEP 9 OF THE SYMPTOM/CONDITION ONE DIAGNOSIS / REPAIR PROCEDURE OF THIS BULLETIN.
16. Insert the new ignition key into the new ignition lock cylinder and attempt to rotate the key to the start position and then the accessory position.
17. If the key turns, remove the key from the lock cylinder and turn it over 180°and reinsert the key into the lock cylinder. Attempt to rotate the key.
18. If the key turns, repeat steps 16 and 17 ten times. If the key continues to rotate smoothly the repair is complete.
SYMPTOM/CONDITION TWO
1. Check the operation of the shift lever. The shift lever should fall freely away from the driver when it is brought up into the Park position.
2. If the shift lever does not seat fully up and away from the driver the column will not allow the key to be removed.
3. If binding of the shift lever is discovered, adjust the transmission shift cable using the procedure outlined on page 21-114 of the 2000 Town & Country, Caravan and Voyager Service Manual (Publication No. 81-370-0005).
Jun 01, 2010 | 1999 Plymouth Grand Voyager
Ignition and steering wheel on 1996 Corsica are locked.
Your key or the lock cylinder may be overly worn, to the extent that the key no longer moves the pins to the correct positions to allow the cylinder to rotate.
Assuming that the lock cylinder hasn't been progressively getting more difficult to turn, you may be able to aggressively rotate the steering wheel against the lock back and forth while attempting to rotate the key to disengage a frozen steering lock.
Dec 26, 2009 | 1996 Chevrolet Corsica
Key lock on my 2003 honda civic does not work on drv door
I am afraid they may have attempted to steal your car and thereby damaging the lock.
Jul 11, 2009 | 2003 Honda Civic
2007 Subaru Outback lock cylinder mutilated
Get a lock cylinder from a dealer and have it re-keyed to your key!
Apr 26, 2009 | 2004 Subaru Outback
Locks & Locksmithing Logo
94 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
