Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have no sound coming from my television. I have checked eveything and I can't come up with a soloution.
My 1000 watt amp is hooked up powers on eveything is connected to the head unit but no sound comes out the sub im thinking the rca jacks r broke
check RCA wires for breaks or bends especially if they are somewhat old and used test speakers on a 9 volt battery to see if the pop and flex and push them straight in and out to see if you hear any scratching sounds
Aug 20, 2011 | Car Audio & Video
HISSING SOUND WHEN TURNED ON. EVEYTHING WORKS OK.
Hissing sound is one or more leaking capictors. My suggestion is that if you have an extended warranty then get a repair guy to come out and fix it right away before you extended warranty expires.
Sep 18, 2010 | Polaroid FLM-4234BH 42 in. LCD HDTV
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
No sounds coming out of subwoofers
CHECK INSIDE UR SUBWOOFER BOX ...
Apr 11, 2009 | Pyle PLAM2300 Car Amp
Problems with sound that buzz/vibration sound My brand new Toshiba 40 LCD has similar occasional buzz/ vibration coming from inside TV
Same problem with my new Toshiba 55" LCD.
Also, after being on for awhile, the sound suddenly gets distorted in a fuzzy, echoie kind of way. Switching to a non-digital channel and switching back seems to make that correct itself. I may try a new HDMI cable to see if the problem goes away. Any other ideas?
Jan 14, 2009 | Televison & Video
Dell W3201c TV
I bought two sets at the same time and the sound has gone out on both,  So far no luck with Dell or a soloution.  The post on attaching a surround system sounds like a good idea, but I can't get this to work.  With a little feed back I'll create a site to log how many have this problem, a few can be understood, but from what I'm reading the sets were defective when shipped and Dell must know of the problem,
Jun 18, 2008 | Dell W3201C 32 in. LCD Television
SOund does not work
Check your speaker if still working, test it with a different audio source or an ohm-meter. Check the plugs & jacks from your audio connections, it may also be a cause of a lose connection from a wire near the plugs of the speaker locate it with a multi-meter or have it serviced with an authorized technician... ^_^
Dec 28, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsumg plasma tv 42
it sounds like the panel is bad..if it is less then a year old you should contact samsung
Nov 08, 2007 | Samsung HP-S4253 Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
