Question about Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive
Maxtor 6L300R0 External Enclosure Problem
I recently bought a Rosewill RX35-AT-IU for my Maxtor 6L300R0 but my computer will not recognize it. The blue light goes on for a second when I turn it on and than turns off. Any help?
  • vdiep311 Oct 06, 2009
    Update: The light stays on but my computer doesn't recognize the fact that a USB Device is connected.
  • 3,153 Answers
It may be a power supply issue but before you take it back to exchange see if any of the hints below are of use.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
  • Project NOMAD
    Project NOMAD Oct 06, 2009
    double check the enclosure connections first.
    If you still have issues connect the drive directly to a suitable computer after removing it from the enclosure.
    That will tell you if it is the drive or the enclosure that is at fault.
Laptop suddenly will not recognize my external hard drive
One thing to try is hooking it up to another computer. There is a possibility that the hard drive failed or the controller for the external storage device has failed. If it is recognized on another computer then I would look at the manufacturer's website for an updated driver
Dec 05, 2017 | Rosewill Computers & Internet
RX355-u not recognized as drive
With the drive plugged in, right click on Computer, Manage, Disk Management. If you do not see the drive in here. There is a problem with the drive or the enclosure the drive is in. Put your hand on the drive and check if it is spinning (vibrating). You can try buying a new enclosure from your local electronics or online store. Open the enclosure and pull the drive out and put in the new enclosure. If it doesn't work the drive is probably bad and you will need to replace the whole thing.
Jan 13, 2013 | Rosewill RX355-U External Enclosure
My Device Manager sees my Maxtor Diamond Max 10 Model 6L300R0 hard drive, but my Bios doesn't. I'm using it in a USB configuration. Any suggestions? If my partition is unrecognisable would this cause the...
Yes, If your partition isn't being recognized than windows has no way of reading the information. thats why windows create partitions to determine the amount of space and data being used. it anything try to access it in my computer and see if you can. if you can its possible to get you info, i recommend ananother external to transfer the data to or if its not that much info put it on a flash drive
Jun 17, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
I purchased a Rosewill 3.5 IDE/USB2.0 External Enclosure. (RX35-AT-IU) I put my hard drive in it, and plugged it into my desk top and it worked wonderful. I later hooked it up to my boyfriends laptop and...
Sounds like it has had the file system corrupted by powering down before it was ready.
Re initialize and format it to get it to work again unless it is an SSD. In that case leave it powered up for about an hour and it will recover.
Jun 20, 2017 | Rosewill Computers & Internet
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive Logo
372 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
