Question about Craft Master Sewing Machines
I bought a used Consew model 22b-6. When it sews it is a fine machine, but somehow I have lost threading diagram, which includes the bobbin diagram. It will not make a successful stitch, or after 2 or 3 poorly balanced stitches the thread frays and breaks. The bottom tension wheel(my name for it)loses the thread frequently leading me to believe I have not threaded everything before that. I can't be sure I have the right needle, though this one came with the machine, or which way the hole should face, front to back or side to side. Can you help?
  • 835 Answers
Im having a real hard time finding anything with the model# 22b-6.
how ever i went to consew.com . here they have a long list of most thier machines, and you can get the instruction manuals off this site also.
You might be able to find a similar model type, and see how it is setup on that machine, and then try your the same way.
as well on that site their are also part books if you ever need to order any replacement parts for your machine.. All the information on this site is free.
as well you can try contacting the company directly and seeing if they can assist you further. the contact info is.
New York Corporate Headquarters
400 Veterans Blvd., Carlstadt, NJ 07072
tel: 212-741-7788* fax: 212-741-7787
email New York Headquarters
Miami Location
4077 N.W. 79th Ave., Miami, FL 33166
tel: 305-513-9220 * fax: 305-513-9417
email Miami Location
Los Angeles Location
2320 S. Hill Street, Los Angeles, CA 90007
tel: 213-745-8844 * fax: 213-745-8855
email Los Angeles Location
Good luck.
Posted on Oct 06, 2009
  • Norman
    Norman Oct 11, 2009
    I was just doing a follow up. I see that you havn't accept or denied my solution yet. I just wanted to make sure that you got this, as well see if the links, and address was any of help to you.
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Top thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 08, 2012 | Consew CN2053R1 Sewing Machine
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
I bought a consew 230 industrial machine, but when I try to sew on it the needle breaks. What do I need to check, the threading, needle or what?
make sure the needle is inserted correctly
check the needle clamp screw to make sure it's tight
the needle is to fine for the fabric being used
also make sure under the needle plate there is no lint
also in bobbin area
also check the tension
Nov 26, 2010 | Consew 206RB
Threading a consew RB-1 sewing machine
There are a few Consew models listed here http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm maybe one will be similar enough to help you with the threading of your machine.
Apr 19, 2010 | Consew 206RB
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Apr 08, 2009 | Consew 206RB
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
Sewing Machines Logo
47 people viewed this question
Top Craft Master Sewing Machines Experts
Andrew Taylor
Andrew Taylor
Mona Randolph
Mona Randolph
Are you a Craft Master Sewing Machine Expert? Answer questions, earn points and help others
