Question about Casio Computers & Internet
Casio CTK 710 works on battery power but not on AC adapter, how can I fix ? The adapter is new.
5 Suggested Answers
jitenok
  • 151 Answers
SOURCE: Casio CTK-710 Electronic Keyboard BUZZING
any key is in pressed position or short in side,or hot key is used
Posted on Feb 29, 2008
wayneard
  • 1901 Answers
SOURCE: Need owner's manual for Casio CTK-500 keyboard
I can help you with the manual. Here is a link:
CTK-500 Manual
I'll try to find an adapter. Are you in the US?
Use the Comment button to reply.
Thanks for using Fixya.
Posted on Jun 18, 2009
SOURCE: My casio keyboards ac adapter does not power up
There is some type of system short. If you read the keyboard instructions it will probably have an "important" note telling you not to unplug the keyboard while in the "on" position. Some how this shorts the connection port. Seems as though Casio could prevent this from happening. I got a refund and went with another brand.
Posted on Jul 24, 2009
  • 3 Answers
Try this out- check for a blown fuse. If you have never done this before, here is a simpler step by step procedure-
1. If you have the tools and little bit of adventurous spirit, I would suggest you open the keyboard and check for a fuse (a small glass tube with a metal wire running through it).
2. Pull it out and look at it against a light source (like a window) check if the wire if cut (that means the fuse is blown).
3. If it is not blown, put it back, if is blown find a shop that sells it- an electronic spare part shop that stocks stuff for TV, and computer spare will have it). Get a new one and put it in.
4. Try plugging the adapter again.
Best of luck...
Posted on Aug 20, 2009
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
Mar 26, 2016 | Casio CTK-720 Electronic Keyboard with...
What do I need to do with my Casio CTK 700 which will make it run on batteries?
If you turn it over, you will see the battery compartment. It runs on 6 AA batteries. Here's a link to the manual. Instructions are on page 13.
http://support.casio.com/pdf/008/ctk_496_700_e.pdf
Feb 25, 2015 | Casio Music
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Ctk 5000 driver
I prefer, only in CASIO authorized service
Jun 29, 2013 | Casio Ctk-5000 Electronic Keyboard Piano...
I have a Casio CTK 551 Keyboard, when the AC adaptor is connected and power is turned on, the Keyboard lights up for a few seconds then turns off. I noticed no red light lights up when the AC adaptor is...
The adapter has a problem... likely a poor connection of input power that briefly contacts building up some voltage that is then stored in the capacitors in the adapter which then discharge quicklly when you turn on the Casio. The adapters with FIXED blades OFTEN have problems contacting the connections in wall receptacles and extension cords. You may need to bend the blades slightly or use a better receptacle like connector. IF your adapter has a three wire cord from it to the wall receptacle, those SOMETIMES don't seat well...
Apr 10, 2011 | Casio Ad5mr Power Adapter Lk Ctk Wk New...
My casio ctk-710 does not work with the power supply, only batteries and i already try several powers supplys
There is a contact switch in the power connector that must be making for batteries to work... I suspect that either the soldering of the power connector or possibly a broken circuit trace to the power inout connector may be the problem.
Oct 23, 2010 | Casio CTK810 61 Key Keyboard
My Casio keyboard won't play with the ac adapter but plays when I install batteries. Why doesn't the ac adapter work?
Test the continuity of your Adapter (input and output), if it fails your test replace it with the same output voltage requirement's and watch the polarity as well (negative ground mostly or positive ground).
Aug 12, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
My ctk 2000 casio keeps shutting off
Replace the batteries and get an AC adapter for it! These do NOT work when voltage os too low.
Nov 21, 2009 | Music
Computers & Internet Logo
118 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
