Question about Dryers
I need to convert a three-prong plug to a four-prong but can't find where to put the green (ground) connection.
  • 672 Answers
Attach red, white and black as they were, Attach green to frame with any existing frame screw in reach or add a sheet metal screw where it is reachable and convienient.
Posted on Oct 05, 2009
I have a maytag neptune dryer #MDE5500AYW and I am trying to convert from a three prong to a four prong connection. the four prong has a red, white, black and green connection. the old three prong, had a...
yes,hook up the black with the black the white with the white and the red where the blue was,now the green is just a ground wire,all you have to do is connect it anywhere to the metal frame of the machine just to ground it,look around there should be a screw somewhere near the other wire connections if not remove any screw and connect it and it will be fine.
Sep 04, 2011 | Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Aug 13, 2011 | Kenmore 700 6972 Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
May 01, 2009 | Maytag Neptune MDE6800A Electric Dryer
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
I have a 3-prong plug on a 14-year-old dryer. Now must change to 4-plug. Is that possible ... and if so, how?
A three Prong contains L1 (Line1), L2 (Line2) and N (Neutral). A four prong will contain L1 (Line1), L2 (Line2), N (Neutral) and G (Ground) typically a green wire.
Connect the three wires as normal, connect the green wire to the screw provided on the cabinet.
Jul 04, 2008 | Dryers
Need help with plug for kenmore elite he quiet pak dryer
if she went from a 4 prong cord to 3 prong cord the only difference is a extra green ground wire... black and red to the out side screws and the white in the middle... not sure what your calling a converter... unless the changeing of the cord.. 4 prong are mostly in trailers here in florida
Aug 25, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryers Logo
60 people viewed this question
Top Dryers Experts
