Question about Homelite 'Yard Broom' Leaf Blower
The fuel line broke and I noticed one only one connection from the carb and two from the fuel tank. I hooked one up and primed it and it ran. What about the other one coming out of the fuel tank? Thanks
  • 437 Answers
One line is hooked to the fuel filter in the tank. It feeds fuel to the carburetor. The other line is a return line from the carburetor. The return connection of the carburetor is on the back side toward the impeller housing.
Good Day.
Posted on Oct 10, 2009
2 fuel lines broke (1 from tank 1 from primer bulb). Line from back of tank to back of carb still there. Which lines go where?
Do not mix them up!! Doing so will bring debris into carburetor. Assuming the line from back of tank to carburetor is the fuel feed line then you should also plan to replace it if the other lines have failed..
The primer bulb sucks (pulls) the air fuel through the carburetor thus venting out any air. The process draws the fuel through the in tank filter through the impulse fuel pump. The fuel connects via an internal carburetor passage from the pump to the needle valve and during the prime passes the needle valve into the pressure diaphragm chamber. From there the fuel is drawn(sucked) into the inlet side of the purge/prime valve and returns the air fuel into the tank.
The center hose on the primer is the return into the fuel tank. The hose from the center of the primer bulb goes directly to the fuel tank and is the return. The outer diameter hose connection to the primer is the connection made to the carburetor. By closing off the end of the hose you can test with your finger the function of each hose. You do not want to pass fuel into the carburetor by reversing the primer hoses.
Dec 06, 2015 | Garden
Replaced te fuel lines. no sure Ihavethe lines connected properly
Not sure if your primer bulb is on the carb or separate but here are some basics... The smaller line is the main fuel line. It has the fuel filter on it and the filter should be laying on the bottom of the tank. That line goes to the fuel pump side of the carb ( usually the inlet near the center of the carb body ). The fuel goes through the filter up the main line and fills the carb then to the primer bulb whether its on the carb or separate. If on the carb the spigot closest to the primer bulb takes the larger line and returns to the tank. That line should go into the tank about half an inch and terminate. If the primer is separate the larger line leave the carb from the spigot on the metering side ( usually close to the edge of the carb body) to the inlet of the primer bulb then from the primer bulb out ( usually center of the bulb) to the tank and terminates about half an inch inside the tank. Remember... fuel filter into carb, carb to primer bulb, primer bulb to tank. If the fuel does not go that direction when the bulb is primed then you have lines hooked up backwards.
Aug 03, 2014 | Ryobi Garden
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 | Boating
Wont prime up
I have seen a couple of different things cause this... Are the fuel lines hooked up and not split and fuel filter routed right in tank.(hanging freely touching bottom of tank lying flat) next if your carb has adj. screws H &L I have seen when the H is cranked snug (lean) that primer won't work right. Last but not least your Needle inlet valve is stuck shut and or the fuel pump diaphram little tabs are not sealing off chambers in carb on fuel pump side. make sure your fuel lines are properly hooked up to the right spots. when you push primer bulb it should squirt gas into the fuel tank, then when you release it ,it should draw fuel from the tank through the filter and thru the carb and then out to tank.
Nov 18, 2011 | Homelite Carburetor Trimmer Blower...
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Gasline mixup
one line comes directly from the fuel tank (the one with the filter) to the inlet side of the of the carbruetor ( the bottom fitting on the carb.usually)
the other line coming out of the fuel tank is the return fuel line and it hooks up to the outlet side of the two fittings on the primer bulb
the other side of the primer bulb goes to the only fitting left to hook to at the carbruetor.
you have 2 different length fittings on the primer bulb itself
the longer fitting is your return line hook it up to your tank side and the short one goes to carb.fitting
when you get it hooked up press the bulb several times and see if it primes as it should(fuel moving thru lines) from tank thru carb. thru primer back to tank
Jul 10, 2009 | Ryobi Garden
Replacing fuel tank on craftsman edger and other fuel lines.......do not understand where to hook fuel lines back up?  any diagrams?
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jun 15, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Homelite 'Yard Broom' Leaf Blower Logo
253 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
