The setup wizzard does not see the print server
  • 2,260 Answers
Is your print server and the computer connected to the router with the Ethernet cable. if not then connect both the print server and computer to the router with the cable.
then try it.
you can press the reset button on the print server for 5 to 10 seconds and you will get a print out ( printer should be connected to the print server).
on this print. you will find the IP address of the print server.
try to open the print server set up interface of the print server.
Click Here for more information.
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
How or where do I enter my code ????
during the set up process, there is a portion that ask for what type of infrastructure that you want to set up and what type of code that you use. You may repeat the installation process using the software cd. and read first everything before proceeding with the next step. Just follow the wizzard carefully.
Jun 28, 2011 | D-Link DI-714P+ Enhanced 2.4GHz (802.11b)...
Tip
Installation CD for the print server
If you are having trouble going through the setup process on the installation cd do the following:
  1. Disable any encryption settings on your wireless router.
  2. Disable MAC filtering.
If these features are enabled during the installation setup process, the wireless features will not work unless you go into the admin settings of the print server by typing the IP address into internet explorer. Type in the correct encryption settings.
Linksys has a provision in the setup software to key in the correct encryption however the software doesn't put the information in properly. This will cause the wireless not to work and allow the print server to work only when it is wired to the network.
Encryption settings have to be entered through the administration settings of the router by typing in the IP address of the print server using internet explorer.
on Jul 20, 2008 | Linksys WPSM54G Print Server
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Cannot access setup utilities in dpr-1260 print server.
Try to log in with "admin" as the P/W (without the quotes.
Jan 03, 2009 | D-Link DPR1260 Rangebooster G...
Browser Setup Access address for DLink DP-301U Print Server
It's in the quick installation guide, which is freely downloadable from their web site. Top of page #3...
"The factory default IP address of the DP-301U is 192.168.0.10."
Dec 18, 2008 | D-Link DP 301U (DP-301U) Print Server
Linksys WPSM54G No Device
Do a reset on the print server. To do this, hold in the reset button on the back, unplug, then plug in and continue to hold for 10 seconds. Your setup should now detect the print server
Nov 11, 2008 | Linksys Wireless-G WPS54G Print Server
Computer not recognizing print server
If you connect your printer directly to your computer, were you able to print? Make sure that there is no firewall enabled in your computer (Double check windows firewall or any personal firewall, that could have been enabled).
Jul 12, 2008 | Linksys PrintServer for USB with 4 port...
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Computers & Internet Logo
516 people viewed this question
David Payne
David Payne
