Question about KitchenAid KUDR01TJ Dishwasher
Kitchen aid dishwasher
Loud noise when turn on
    Novelist:
  • 148 Answers
Something in the impeller of the pump, most likely.
will be difficult to get to it if that is the issue.
do not run it with the noise, as you could cause more serious damage.
clear the clog if you can. also, with the front plate off, you might be able to start it for a brief moment to try to locate the source underneath.
careful.
good luck
mark
Posted on Dec 28, 2007
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
I have a new kitchen aide dishwasher. Does any of the insulation padding come off before installation
No. It is supposed to remain on the dishwasher. It helps cushion the machine noise from vibrating through your counter.
May 26, 2012 | KitchenAid Kitchen Aid - KUDC10FXSS...
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
Kitchen Aid Model KUDPQ1FLSS5 door counterbalance issue
One of the counter bakance springs OR the adjuster for it let go. I had a similar thing where the adjuster which was a thin metal "T" thing that screwed up into the spring as an adjuster folded and fell out of the spring.
Remove the bottom dress cover at the tope kick of the dishwasher. The springs are all accessable right there. The problem will be obvious. Just compare the two sides.
I had to beef up the "T" adjsuter in mine as it was too weak to continue holding in the spring.
One turns it into more or less coils of the spring to adjust the counterbalance.
Apr 21, 2010 | KitchenAid Dishwashers
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Dishwasher makes a loud noise until I turn on the water in sink
You have too much water pressure it sounds like for the fill valve to operate properly. I am assuming it is chattering? How much water pressure do you have? If its too high an inexpensive regulator can be purchased at most plumbing supply stores to install in the DW supply line.
Jul 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
KitchenAid KUDR01TJ Dishwasher Logo
171 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
