Question about Kenmore Dryers
I have a kenmore series 70 model #110.66742500 that heats up but wont spin. The belt is not broken and the pulleys are fine. Any suggestions to what else it could be? Thank You
  • countrymom20 Oct 07, 2009
    No I cannot hear it running, thanks
    President:
  • 1,304 Answers
The motor
when its running and heating can you hear the motor
running
Posted on Oct 06, 2009
  • milten1
    milten1 Oct 08, 2009
    i sure hope that was helpful
I have a Kenmore 70 series dryer that is not spinning. When turned on u can here the Moter but it won't spin. Belt looks ok.
Is the motor pulley rotating? if it is , how tight is the belt, is the motor pulley turning and the belt slipping? Is the motor weak perhaps, if it is not turning, or has lost power it may need replacing. if it does rotate and the belt is slipping replace the belt and possibly the pulley if you have that option.
Jun 24, 2015 | Kenmore Washing Machines
My kenmore electric dryer 70 series wont turn. it turns on and heats up but it doesnt spin. what can i do to fix it? i have aparts dryer to use. just need to know what to do. thank you very much
you mayu have a broken belt if you take the cover off you should be able to see if the belt is still on there if not you can get a new one should be pretty cheap.
Nov 12, 2010 | Dryers
My kenmore 70 series washing machine wont spin. i took it apart and could see the belt off, but i couldnt figure out how to put it back on
just place the belt over the motor pulley
then get it started over the drum pulley it will stretch on by rotating the drum pulley
Mar 09, 2010 | Washing Machines
I am having trouble replacing my belt on my Kenmore 70 series
i've got them down to 10 minutes, but here goes. remove the bolts going into pump, but do not remove pump . remove the transmission bolt with the spacer and this is where you push the belt through and around pulleys.. this is a little more difficult. you will need to take off the yoke spring and move the transmission pulley around until the spin control magnet catches for spin. it will begin to take pressure off of clutch. you will need a long screwdriver or something like it to apply pressure down on the clutch plate this is to allow to to slip the belt thru the bar the spring came off of and under it.. you can then pull the belts around all pulleys and put everthing back in its place and your done...
Jul 18, 2009 | Kenmore Washing Machines
Kenmore Series 70 won't spin
Sounds more like a transmission or a spin tube problem
Jul 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
166 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
