Question about LaCie Computers & Internet
Makes a loud sound when plugged in was dropped 1 foot off the ground does not work when usb is connected to computer
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
Loud humming sound
Make sure that the input connection ground is good. If that does not cure the loud hum then you have a power supply issue.
Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
My PC has two USB controllers. How can I access the second one?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if all are intact
you might purchase a usb 2 or 3card they almost install themselves and a very cheap on Ebay or
purchase a usb 4 or 5 port hub if you already have one
think about fixing the sound insteab of us
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
May 10, 2012 | Computers & Internet
When I install the c613 usb cable into my usb port, it does not transfer pictures anymore, and makes a beep sound...why?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 16, 2012 | Kodak EasyShare C613 Digital Camera
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
The sound is terribly distorted if turn up the volume on my ion profile pro
I am going to hazard a guess, I have lots of experience with traditional turntables, but not with USB turntables. Here is some theory that may also apply to the USB turnbable. Turntables of old and new that are not USB have a GROUND wire (a single flexible conductor not connected to the plug). The ground wire is supposed to go to the chassis of the amplifier or receiver. If it is not used. There will be a 60Hz hum added to the turntable's signal. It makes the sound garbled and unpleasant. Your turntable may have such a wire. If so, ground the wire to the chassis of the computer. If it doesn't have the wire. check to see if you have all three prongs on your terminal strip(the rounded large prong is the ground). If you don't the chassis of the computer will not be grounded so you may get the hum from that source as well. If the outlet that your outlet strip is plugged into does not have a proper ground, then that could be the source.
Check to make sure that there are no breaks of your ground between the turntable and the wall outlet.
Replace the offending cables or parts until you are sure.
If there is a grounding wire coming out of the turntable, connect it to the chassis of the computer.
Here are some other points that are important
Important: All of the power in your computer and sound system should be connected to the same phase of the breaker panel in your house If it goes into the same wall outlet. that is best.
This ground issue is important in turntables.
This may not be the problem, but it certainly is very possible.
I worked in professional sound system design for recording studios and large venue (concert) sound systems.
Whenever possible, these folks require the power to be from a unified phase and source point. on Otherwise they have serious hum issues.
Have a Happy New Year,
Best, mark
Dec 31, 2010 | ION Audio Vinyl Recording Turntable
Hard Drive Dropped
Turn off your computer and then plug in the FreeAgent external drive. Then try turning your computer on, it should read.  If it doesn't I would go to the Seagate website for troubleshooting.
Jan 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Camera Is Not detected by computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 27, 2009 | Canon PowerShot SD1100 IS Digital Camera
HARMAN KARDON SOUNDSTICKS 1
WRONG IDEA, YOU CANNOT MAKE AN OUTPUT SOUND ON YOUR MP3 THROUGH USB, THE BEST THING THAT WORKS IS ... REPLACE YOUR HEADPHONE WITH A CORD [AUDIO JACK] AND CONNECT IT TO YOUR PC SOUND CARD THROUGH AUDIO INPUT HOLE. .. THIS REALLY WORKS... PLEASE VOTE FOR MY POSTING
Oct 20, 2008 | Harman Kardon SoundSticks Computer...
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Computers & Internet Logo
37 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
