Question about Mitsubishi WD-52525 52" Rear Projection HDTV
We recently changed the bulb cartridge. We receive broadcast tv, no cable, no sat. Our WD-52525 had worked perfectly until we changed the cartridge. Now it will not stay on, it shuts down and the green light blinks. I have been through the owners guide thoroughly and have followed all the proceedures completely with the same result. Do we have a faulty cartridge? Can anyone help?
  • 336 Answers
Hi the cartridge's work is to hold the lamp in place it will not go faulty or melt or will prevent tv from lighting up.Did you close the door cover on the back properly.Did you reset the lamp timer? Do it by unplugging tv wait 5 min and plug it back again.Pay attention to clicking sounds or like wanting to turn on it could be a bad ballast and that's the board that powers the lamp.Hopefully you dont have "The green light of death" Issue. It tells all about it here http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Good luck and God bless you!
Posted on Oct 06, 2009
I need a Mitsubishi 52525 schematic to get to the back of the bulb compartment. I tried to replace the bulb and the two plugs on the TV fell out behind the bulb compartment in the TV. Any help would be...
just remove the rear cover and then you can slide the lamp leads back into their slot that is at the rear of the lamp cartridge area. Its very common for them to get pushed back inside the lamp compartment but removing the rear cover will allow you to slide them back into the compartment.
Aug 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Hi, I recently acquired a WD-52525 for free from a garage sale. The woman told me they just recently replaced the bulb but it no longer turns on (was working up until 2 months ago apparently). When I got...
If the TV's are noted for bad caps, and the description of the error makes that possible, the only fix is to remove all bad capacitors from the boards and replace them with new ones.The bad ones are easy to spot because they usually are either bulged at the top or have goop running out of them, or both.
May 22, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi WD-52525 is broadcasting at 480i, is there a way that I can make it broadcast at 720?
Hello!! Well it is possible.. what you would need to do is go to your menu and select settings, then go to video and then select display to make the change, of course just letting you know that it varies depending the tv model so you will need to check your service book, to see if it does support it :)
Jul 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No HDMI audio at all.
Could be lots of things, from bad cable, to your laptop no outputting sound, to your tv not functioning properly. A work-around might be to use the VGA output (and sound output) from your laptop until you can resolve it better.
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
wait the 4 days. any work done on it by a non authorized party could ruin your warranty
Dec 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
