Question about Samsung HCL5515W 55" Rear Projection Television
I replaced STK392-040 covergence appeared then quickly left.
  • 1 more comment
  • bweddings Oct 06, 2009
    There was no convergence I replaced the stk392-040 convergence came in but quickly left
    no convergence I replaced stk392-040 convergence came in then quickly left
  • 10,594 Answers
I think convergence setting menu appears and then goes off because STK392-040 does not work.
Please check supplied volts to STK392-040 and make sure there is no bridge soldering on STK pins or any other points that you worked recently.
All connectors are intact/ plugged properly that were removed in repair work.
If you need further help, let me know problem with details as "I replaced STK392-040 covergence appeared then quickly left." does not help me to understand what is the problem.
Thanks.
Posted on Oct 06, 2009
  • Samsung Master
  • 19,396 Answers
You may have blown again the recently installed STK. Test continuity on the resistors at the base of the convergence ICs on convergence board.
  • 11,896 Answers
You should check the contrinuity of the stk as well as others. Most often more than one goes at a time, or one right after the other.
  • 647 Answers
Did you check the Resistors or replace any resistors (3.9 ohm Ibelieve)? If not look there first. Did you replace both IC's and what were the symptoms b4 you replaced them. By "covergence appeared then quickly left" do you mean the convergence was all good and then it went out again? Too much missing info reply to this or post again with more info and try to help.
Posted on Oct 05, 2009
  • johnnydiode
    johnnydiode Oct 06, 2009
    More info required
  • johnnydiode
    The resistors are next to the Convergence IC's and 1 or 2 of them are usually blown if the IC's are bad - I've fixed at least 30 of these sets
My panasonic PT-47wxc43g projection tv has developed shrinkage in the middle of the screen on both the top and bottom. The picture has an hourglass on its side appearance. The picture is now also too large...
This could be a problem in the convergence board which will cost of repair would range 400.00 or so.
You can get the convergence repair kit at the following link which contains the parts and step by step detailed instructions.
http://www.tvrepairkits.net/panasonic_repair_kits
Thanks
Kevin
Jun 29, 2009 | Televison & Video
Covergence
Yes. double check for bridged solder or open as well. If everything checked ok, disonnect the related convergence yoke and see if it fixes it (do this very quickly tho). dont let the set run more than a few sec! its a good idea to scope the output too.
gdluck!
mertronics
ca
Feb 02, 2009 | Samsung HC-P4741W 47" Rear Projection...
Zenith R56W36 covergence problem
you will need to replace conv ic's then auto converge..
Oct 19, 2007 | Zenith R56W36 56" Rear Projection...
Samsung HCL5515W 55" Rear Projection Television Logo
150 people viewed this question
Henry  Thomas
Henry Thomas
