Question about Pioneer DEH-P6400 CD Player
Popping and Humming noise from my audio system?
I have an 04 Chevy Avalanche with a Pioneer Avic Z-1 head unit using the factory amp to the up-graded Kenwood door speakers with seperate Tweeters. No humming noise is heared at this point, but when I connect the Sub RCA's to the 2000 watt amp which are connected to two 10" Woofers, I get a popping noise when I turn on the unit. Once the Pop goes away after the current reaches the amp. I hear a static humm like sound. If I move the settings on the Amp. I can make most of the noise go away but the bass is not as hard as it should be. What can I add or do to make this noise go away and still use the amp to the full capacity? I am not sure if a ground loop or a Power lead filter is needed? Please Help! Thanks in Advance.
    Scholar:
  • 67 Answers
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Posted on Oct 09, 2009
This unit motorhome with a avhx2700 radio unit. we have a very distorted navigation screen got any suggestions
[PDF]AVIC-U260 - Pioneer
https://www.pioneerelectronics.com/.../AVIC-U260+O... Pioneer CorporationPIONEER AVIC-U260 - for Canada 8. - END USER .... ing or distortion and, most importantly, with- ...... After a short pause, the navigation screen ap- pears.
AVH-X5700BHS - DVD Receiver with 7" Motorized ... - Pioneer
www.pioneerelectronics.com/.../AVH-X5700BHS
Pioneer CorporationFeb 16, 2015 - For more information, visit pioneerelectronics.com/AppRadioOne ....Easily upgrade to navigation with the addition of the AVIC-U260 add-on ...
GPS Navigation ' Pioneer Electronics USA
www.pioneerelectronics.com/PUSA/.../GPS-Navigati...
Pioneer CorporationCar Navigation Systems products with built in bluetooth handsfree technology. Includes dvd gps navigation: in-dash and portable. ... AVIC FEEDS App.
Jan 13, 2016 | Pioneer AVIC-U260 Add-on Navigation Unit...
I have power and everything to my head unit, but the sound isnt very loud, and everytime i switch radio stations, the speakers make a popping sound. Did i connnect something wrong?
Your system has a factory amp, you need a different harness or you need to bypass the amp. Knowing the make/model/year of the car would help.
Aug 15, 2010 | Pioneer DEH-P4100UB
I have a Pioneer DEQ-9200 DSP Audio Processor
are your power wires and your rcas on oppsite sides this may be your problem
Oct 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Don't know how to set the clock on the Pioneer AVIC-D2 head unit
drop by your local car stereo dealer and ask them NICELY to reprogram the time for you...then, a NICE person would but the guy lunch, what $10?
Good Luck
Jun 15, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Stero works with engine off
Some wiring may be crossed between the Ignition wire and the 12V battery wire. Check the wires behind the head unit. The head unit could also be going. Hope this helps!
Aug 03, 2008 | Pioneer DEH-1600 CD Player
Pioneer DEH 3700 ground problems/system noise
Very common with pioneers. their is a ground loop fuse-located inside the head unit, that has to be repaired at the factory. Or, the best way-just like you said, is to ground the rca's, solder a thin wire to each rca, easiest and cheapest way. I had it happen to me with a 4800.
Mar 23, 2008 | Pioneer DEH-3700MP CD Player
Problems with pioneer avic d3
I have had the same problem here in Australia and i have been told that Pioneer has a software upgrade. So take it back to your retailer and get them to reinstall the new software.
Good Luck
Tony Turner
Mar 10, 2008 | Pioneer AVIC-D3 Car DVD Player
Connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
Dec 28, 2007 | Pioneer GPS AVIC-X1 car radio
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
MY MONITOR SCREEN DOES NOT COME OUT HELP PLEASE
hi Bips07.
Apparently, this model has an Achilles heel...the ribbon that controls screen extension/retraction. I believe Pioneer extended warranties on this model to 4 years if purchased via a pioneer main dealer or sub contractor. Problems normally occur within 18-24 months from new. I assume your unit is at least 18 months old. Best to contact place of purchase or Pioneer directly.
May 21, 2007 | Pioneer AVIC-X1R CD Player
Pioneer DEH-P6400 CD Player Logo
543 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
