Question about Zalman Tech ZALMAN ACCESSORY ZM-NC1000S COOLER FOR NOTEBOOK SILVER Laptop Cooler
The fan is making a clicking noise, its on the left side and ive tried to blow into the fan, but it makes no difference. Its about 4 months old.
    Genius:
  • 1,027 Answers
It probably sucked some object into the fan. the only way to clear it, is to open the laptop up and extract whatever is in the fan.
Posted on Oct 05, 2009
My LG French Door Refrigerator Cooling Fan makes noise.
fans that make noise in no matter what they put them in , most times has something stuck to blade that makes it spin out of balance , hence it rocks slightly from side to side and makes noise , ive found that formula 409 and a rag makes quick work of stuff stuck on fans
Nov 22, 2016 | LG Refrigerators
Heater is blowing cold air and there is a noise coming from around the blower motor area?
Check your coolant reserve tank and fill it if needed.
If the coolant is fine try flushing the heater core, follow ChrisFix's instructions in the vid linked below.
How to Flush Heater Core Safely with garden hose
As a side question:
Were there any loose wires that could have been caught near the fan when you replaced it? They'll make a buzz noise if they're touching the fan blades.
Jan 18, 2016 | 1991 Honda Accord
HI, my laptop is three years old, getting some noise from the fan, My question is can the fan be lubricated,
Have you tried blowing air through the cooling duct to clean out the dust that gets caught up in there?
Nov 13, 2013 | HP (158800-001) for Compaq Presario 1246,...
Connectivity
Update the Firmware
Click here
And before downloading the firmware make sure you download the correct version
Then
Connect your computer - Router (Wired)
Open router setup by typing 192.168.2.1 on the address bar of internet explorer
on the left under utilities click firmware update
Leave the password blank and click submit
Click browse and locate the file you downloaded
Click open and click update
Then on the left side under wireless click wi-fi protected setup
Disable it and click apply changes
on the left under wireless click security
select the security mode as 64 bit wep
on the key one type a 10 digit number
make sure you remember it and click apply changes
on the left under wireless click channel and ssid
change the ssid to a different name and click apply changes
Try to connect to this network on your computer
Jul 19, 2010 | Belkin F5D7234-4 Router
Severe noise problem onthe left side of the machine
That is the fan making noise if it is under warranty take to a sony service centre otherwise it is not a difficult job to replace you just need to take out all screws on bottom making sure you note where each goes as there are different types,then fan assy is held in by 6 screws and 1 connector.
Feb 15, 2010 | Sony VAIO VGN-CS260J/P Laptop
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Still got my clicking coming from inside my laptop
Usually, the clicking means your hard drive is about to fail. Unfortunately, there is no much you can do about it. Since your PC is 4 months old, you should still be under warranty. Just ask them to replace it.
If they won't, you can get pick a brand new one online at decent prices.
Good luck
Dec 06, 2008 | Compaq Presario Notebook
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Zalman Tech ZALMAN ACCESSORY ZM-NC1000S COOLER FOR NOTEBOOK SILVER Laptop Cooler Logo
101 people viewed this question
Top Zalman Tech Computers & Internet Experts
waruna
J D Wright
Bill Boyd
Are you a Zalman Tech Computer and Internet Expert? Answer questions, earn points and help others
