Question about Dishwashers
Smoke comes out of top right corner during wash .whirlpool dishwasher model # GU1200XTKQ0
  • 672 Answers
This is most likely steam. To allow water to enter the machine, air needs to exit. It exits through this vent. As the machine heats the air inside expands and exits along with the steam from the hot water and you are seeing it come out through the vent. No wories they all do this. Have a safe day.
Posted on Oct 06, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a whirlpool quiet partner II the air dry button keeps flashing I cant figure out how to reset can someone please help
It is likely the button is faulty inside the panel. Have you tried to turn the mains power off and back on. If this makes no difference, open the panel from inside and get a hair dryer and dry the switches. Sometimes water vapors or steam can do it. make sure the dishwasher is plugged out from mains when you work on it.
The module is item 1 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU1200XTKQ0/1198/0130000/W0503063/00002?blt=06&prst=&shdMod=
Apr 01, 2014 | Dishwashers
I have a whirlpool model number du810swpq3 dishwasher. It began to emit smoke during the washing cycle. I immediately began to suspect a belt problem but this model does not have a belt. Any suggestions?...
You have to check the water pump.Solenoid valves. Check whether any electrical part getting over heated!
Switch of the machine after a short 5 mins run and check
Apr 07, 2010 | Dishwashers
I have a GU1200XTKQ0 Whirlpool Gold Dishwasher. I
If you have a Wet/Dry Vacuum, then you can use that to **** up any debris you see in the bottom of the Dishwasher. Make sure you remove the paper filter from the vacuum so it does not get damaged from the water in the bottom of the Dishwasher. I use the vacuum trick to clean up the muck from the pump area and it works well.
Apr 04, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Smoke emitted during early stage of wash cycle, smell also; no problems to this point, all has been well with machine.
Not knowing any additional info on your dishwasher,one thing that comes to my mind is GE has had some recalls on many dishwashers that was to do with electrical failures, you should give them a call at 1-800-626-2000 or access their website at www.geappliances.com and type in "dishwasher recalls" in the search box at the top right of the page.
Good luck and Happy Holidays!
Dec 24, 2009 | GE Nautilus 24" Built-in Dishwasher
My whirlpool model # DU943PWKQO has power to it, but no power
There is a thermal fuse in the top right corner of the control panel that will need to be replaced.
Aug 14, 2009 | Whirlpool 24 in. DU930PWP Built-in...
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Feb 25, 2008 | Dishwashers
Dishwashers Logo
225 people viewed this question
Top Dishwashers Experts
