If there is no frost on the rear wall , inside the freezer , then the main control board is bad . This board , is located behind the refrig , behind an 8 " X 10 " panel . The part number is WR55X10656 . This board , probably has a burnt compressor module , keeping the compressor from running . The board is easily replaceable .
Comments:
Oct 06, 2009
- If there is frost , then a defrost problem is evident . Please reply back , if this is the case , and myself or another expert , will give you the procedure for determining the inoperable part .
have ge side/side, water in door dispenser but not in ice maker, disconnected water line at valve to...
(More)
have ge side/side, water in door dispenser but not in ice maker, disconnected water line at valve to ice maker and had water.
I have a GE Profile side-by-side refrigerator/freezer. Ice in ice maker melts, the re-freezes,...
(More)
I have a GE Profile side-by-side refrigerator/freezer. Ice in ice maker melts, the re-freezes, causing huge ice clump.
My fridge freezer is working but not fridge it is warm plus the freezer is not as cold as it should...
(More)
My fridge freezer is working but not fridge it is warm plus the freezer is not as cold as it should be but its making noises as though it is please help
