Question about Dryers
Dryier doesn't dry is not heat - Dryers
  • yadayada
    yadayada May 11, 2010
    make and model please.
  • 82 Answers
If your apliance is gas-dryer you need chek:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Posted on Oct 06, 2009
Elec. clothes dryer turns but won't dry
If dryier is 220 V, phase is burnt out, so it's working on 110V, not enough to heat the air. Check your breaker and electric system or dryier.
Jun 02, 2015 | Dryers
No heat in EH5 dryier
do you get heat when you first start the dryer ? if you do i would replace the coils and check venting , if not i would check the igniter to see if it is broken
Feb 17, 2013 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
Ice stuck in the dispensing shute.how to melt the ice without switching off the refrigerator
I would make this as a suggestion but CARE must be taken while doing this as it can cause fire.
You can use a portable hair dryier to heat the ice but you must be very carful as temperature from this can damage plastic and cause fire.
Heat the ice for 5 to 10 seconds and remove the dryier away from the fridge and wait up to 2 minutes and try again.
If you feel that it is too hard for you to do this then your must shut down the system.
Sep 28, 2011 | KitchenAid Architect II KSCS23FSMS...
My hoover washier dryer has stopped heating up. I works ok as a washing machine but the tumble dryier doesnt heat up. It is a hoover vhw654d washier dryier
on all dryers you have a hi and a low relay as well as the heater and in some you even have a run tstat check that you have continuity on each side of each of your relays as well as your heater any of these pieces that does not have continuity would be the one that u wuld replace hope this helps if you are not electrically inclined plz call a technician
Jul 21, 2010 | Hoover Dryers
Where would I find the heating element on my dryier. My dryier stopped heating and I am trying to check the heat element.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 23, 2010 | Whirlpool LEB6300 Electric Dryer
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
Dryier does not Start
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
Jul 21, 2009 | Maytag LSE7806A Top Load Stacked...
Dlg 5932w
My suggestion would be to make sure that the lint-filter and the exhaust flex hose are removed and cleaned. If you have the plastic type flex-hose, be aware that these can heat up and catch fire. Be sure to also check the exhaust port coming out of the dryer (that the flex hose attaches to); make sure that there is nothing obstructing the air flow, if there is, then clear & clean and try to restart. If not, I would call a service company...
Jan 12, 2009 | LG DLG5932W Gas Dryer
The dryier does not heat
the problem are your gas coils are faulty
Jul 26, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
