Question about Garden
John Deere 160T lawn tractor's new battery will not stay charged.
    Sniper:
  • 197 Answers
Check to see if you a voltage regulator on the left side of engine cover.Three wires going to it.If you dont you have a 3 amp charging system and they are known for going bad and discharging your battery.If you have an external regulator replace it.
Posted on Nov 14, 2009
  • 157 Answers
Sounds as if the charging system on the machine is not working you will probably need to carry it to a small engine mechanic to fix the problem
Posted on Oct 26, 2009
I have a sst16 and the battery will not stay charged any suggestions as to what the problem could be. I can not find the fuses is there a diagram
battery will not stay charged Deloris, Have battery tested could be bad (lucky to get 2 seasons out of one). You have to see if charging when running with a digital volt meter. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test small engine charging system battery alternator
Repairing the Charging System on John Deere 175 Lawn Tractor
Electrical System Troubleshooting for Lawn Tractors Mowers
Apr 03, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
I have a John deere 260 riding lawn mower and the battery doesn't charge and when I disconnect thebabattery it dies
Check the charging stator usually under the fly wheel. Check wiring first before condemning the unit.
Aug 22, 2013 | John Deere Garden
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Lawn Tractor will not start
check for power at the solenoid then put power to the small terminal at the solenoid and see if that turns it over then check the the safety switches
May 20, 2012 | John Deere Garden
The charging system on a C425 John Deere riding lawn mower will not charge the battery.
It could be that the battery is not taking a charge. If you have an external battery charger, try taking it out and charging it.
You should also be able to take the battery into your local auto parts store and they can test it for you for free.
If the battery tests good then you probably need to replace the alternator.
Jun 08, 2011 | John Deere Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
May 08, 2009 | Garden
Garden Logo
213 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
