Question about Onkyo TX-DS838 Receiver
Onkyo TX-DS838 Issues
Left front speaker sound seems weak. Fan no longer works. "Protect" now comes on when volume is increased. Remote volume no longer works. Is this receiver worth taking to someone to repair and approx. what would it cost? Thanks!
  • Anonymous Jan 12, 2008
    When we press enter from our Onkyo remote, the sound turns off and the receiver locks up and won't come back on--even after a system reset....
    when we press enter from our Onkyo remote, the sound cuts off and the receiver locks up, even after a system reset....this receiver gets in knots easily...does anyone else experience this problem
  • 4,234 Answers
The problem here is that the output amplifier section has a problem. This is detected internally and the system shuts down in a "protect" mode. The output section really only kicks in when you attempt to bring up the volume. Another possibility is a problem in the "front end" where DC current is being passed to the amp section. Without takeing measurements, it is difficult to determine the exact cause. This should be a relatively stright-forward repair for a service shop and should cost about $20-$40 in parts plus the local labor charge.
Dan
Posted on Mar 17, 2008
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
Onkyo TX-DS838 Receiver. Mine just sparked smoked
Not worth repairing until the root cause of the failure is proven.
The reason being is that you can have it happen again if caused by any of the devices attached to it, such as inefficient speakers.
Jun 06, 2010 | Onkyo TX-DS838 Receiver
My onkyo tx-ds838 motor fan do not move
The fan in those Audio System only turns at about 1/4 to 1/3 of the ride of your volume control.
It had been intentionnaly designed like that, to achive a quiet operation at low hearing volume.
But if the fan don't move by cranking up the volume at 1/2 to 5/8 of the volume control (with speakers on). You need to have the fan or the fan power circuit checked by technician.
Spider Guy
Mar 15, 2010 | Onkyo TX-DS838 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
TX DS838 WHEN TURNINGVOLUME DOWN UNIT MAKES A POP SOUND
Sight unseen my money says the new problem is a direct result of the 'repair' to the channels that are giving you problems now. You didn't elaborate on what it was you were trying to fix in the first place. Backtrack your steps and undo what you can to see if the bug changes.
Dec 11, 2008 | Onkyo TX-DS838 Receiver
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
Onkyo TX-DS838 Receiver Logo
273 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
