Question about Jenn-Air M170 Microwave Oven
I have a M170. It blowned the fuse. So I bought a 250V 15A Ceramic from Radiosack and replaced but it blowned fuse again
    President:
  • Jenn-Air Master
  • 1,922 Answers
The hv diode or hv cap or the magnetron are shorted and need replacing
Posted on Oct 06, 2009
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
Onn microwave fast acting ceramic fuse f10 250v
If that fuse has blown, check the door switches for a faulty switch.
Mar 07, 2011 | Microwave Ovens
The fuse in my microwave oven is burnt. It was rated 15A 125V. Can I replace it with a 15A 250V fuse? What are the pros and cons? I don't want to risk damaging the appliance.
Yes, if it will fit in the holder tightly... you can always change a low voltage with a higher voltage but never take out a 250 and install a 125...
heatman101
Dec 24, 2010 | Microwave Ovens
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
Fuse is blown
It's 20mm !!
It will have failed for a reason.
At 15amps, I'm guessing your Microwave has a grill too.
It could just be a bulb failure causing the fuse to blow.
Replace it and try again.
If the oven works but no light, that was the cause.
Apr 26, 2009 | Microwave Ovens
Need a replacement fuse for an Emerson Microwave Model MW8774
Please understand there are some liability issues that Emerson or their parts supplier have in selling you the fuse.
You should be able to find one by going online and searching with the terms you gave, using Google. I just did, and there are a number of hits to choose from.
Try Sears Parts Direct or Repair Clinic as well. You will need to enter your model number to find the parts listing.
In all likelihood, you have a failed controller board or microwave circuit (magnetron, transformer, diode, capacitor). Be prepared for additional troubleshooting.
REPLACE THE FUSE WITH AN EXACT REPLACEMENT> DO NOT REPLACE WITH A LARGER (more amps) FUSE TYPE.
Jan 16, 2009 | Emerson MW8777W Microwave Oven
What amp of fuse do I need
There should be a paper tag near the fuse holder, or the fuse holder itself should be marked as to current requirement.
Most older or smaller models used 15A or sometimes 12A ceramic fuses.
Newer or more powerful models use 15A or 20A ceramic fuses.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Emerson MW8625W Microwave Oven
No power
The door switches are designed to prevent the unit from running while the door is open. You probably have a blown fuse, and it's a white or dark grey ceramic fuse of 15A or 20A, available from local big box stores or appliance parts stores. The fuse is usually located on the floor of the chassis behind the control panel, or mounted in the same area as the door switches. Also, I'm really curious how the door switch got stuck while cleaning? That sounds scary...
Nov 13, 2006 | Kenmore 62622 Microwave Oven
Open Questions:
See all Jenn-Air M170 Microwave Oven Questions
Microwave Ovens Logo
310 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
