Question about Philips 51PP9100D 51 in. Television
How do I factory reset my Philips 23pf5320
I was changing my component cables from my cable box to my DVD player when I lost all my sound to my Philips tv. I'm confident my cables are hooked into the correct colors but possible changed my tv sound settings.
Did you have the power supply connected to any componet in your system while making connections , {not just on stand by} ? if so you have probably blown your tv's amplifer. never ever connect or disconnect audio or video connections without disconnecting ac power from the entire system !!! you may or may not get lucky doing this for a good while but sooner or later fate will track you down.
Posted on Feb 07, 2008
Screen on Philips Flatscreen HD has turned green there is sound on all Freeview stations only, no picture but DVD player works perfectly well and in full colour Why is this and what needs fixing. Freeview...
If the hookup is HD from a box you have Green(video) Blue and red--check first they are connected properly at both ends. Component would also use two more cables for audio.
If HDMI maybe a bad cable or issue there. HDMI has issues with and creating no sound problems.
If a DVD player does work fine it means a hookup issue of some kind or a very odd problem in the set(unlikely).
SD TECH
If using HDMI at least attempt a component hookup.
Apr 22, 2012 | Televison & Video
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Sep 26, 2008 | Bose Lifestyle V20 System - black Theater...
No picture after resetting by pressing stop button for 20 sec
Problem fixed: I realized that the problem was that with resetting the player it defaulted to the standard video ouput ie no longer sending signal through the component video. I used a standard video cable and connected player to tv with that and it had a picture. Then I changed the setting to progressive output and got picture signal through the component cable again.
Aug 15, 2008 | Cyberhome CH-DVD 300 DVD Player
HDTV cables
Pressing INPUT on the remote control
displays the current signal source
(press INPUT again or 0–8 to change and be sure is on hdmi 1 or 2 if not let me know , to reset to the factory default settings
your raring to my answer highly apreciate
thanks
Jun 29, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Setting ***.
You will have to change the dvd player resolution to 1080i (or change resolution for each individual disc), because:
a) there is no way to change the resolution manually on this television
b) this TV maxes at 1080i, hence negating most of the utility of using an hdmi cable (Of course, hdmi cables are much easier to hook up, less messy than component cables; so all is not lost)
Mar 19, 2008 | Philips 32PFL7332D 32 in. LCD HDTV
Philips 51PP9100D 51 in. Television Logo
273 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
