Question about Thermador SC302T Electric Double Oven
Thermador SC302T won't reach temp (stuck at 100 degrees)
Our Thermador SC302T gets stuck at 100 degrees. This will be the 4th or 5th repair in 8 yrs. I've been told by the repairman there is a high temperature sensor that shuts it off ( pretty ridiculous for a self cleaning oven that hits 500+ degrees). It can only be reset so many times and then then the "panel" needs to be replaced. Any ideas how to reset it my self - I will never by one of these again!! I've spent more in repairs than I paid for the oven.
    Top Expert:
  • Thermador Master
  • 12,962 Answers
Sounds like you have a real POS on your hands. I would chuck it and get another unit rather than waste any more time and money on this Thermador.
Posted on Jun 20, 2017
SOURCE: Thermador Oven won't heat after running self-cleaning cycle
I also had this problem about 11 years ago. A repair person came, pulled the oven out about 6 inches and inserted a pointed tool (an awl or skewer works great) and reset the oven. He then tried to charge me for this!! On my oven it just looks like a tiny hole. It works every time! And yes, my oven never works again after I clean it without doing this. Good luck.
Posted on Apr 24, 2007
SOURCE: Dimming temperature and clock light on display window
I had the same problem, I think it took place when my cleaning person washed it as the motherboard and lcd have very little protection form the top of the oven.. where it would be wiped down
Posted on Nov 12, 2007
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Highest temperature during self clean mode?
different brands, different models, different temps. they al range from 900 degrees up to 1300 degrees.
Apr 06, 2014 | Thermador SC302T Electric Double Oven
Where can i find a relay board #492069 for thermador model SCD302TP?
try having it rebuilt at core centric solutions dot com. they bring new life to most old electronics.
Feb 09, 2013 | Thermador SC302T Electric Double Oven
Heating element in upper oven heats to about 300 degrees and temperature will not increase.
That seems to me like it could be an issue with the sensor. Ohm it out. It should be around 1100 ohms if it is any good. Check for shorts from each wire of the oven sensor to ground. I have a manual and a TIP I wrote about these Thermadors.
Thermador 301/302 wall oven repair manual
Sep 28, 2010 | Thermador SC302T Electric Double Oven
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
Sep 27, 2010 | Thermador SC302T Electric Double Oven
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Thermador alarm goes off about every 45 seconds by beeping six times. says F25? what is that and how do i fix it?
F25 means "multiple keys stuck". Try pushing each button on the keypad a few times ... maybe you can unstick them.
Feb 20, 2010 | Thermador SC302T Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
F7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Jan 11, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
190 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
