Question about AT&T Cell Phones
Stuck on millatery time
People have told me to go to time format but i cant find time format under time and date settings
  • AT&T Master
  • 8,404 Answers
Look for "options" maybe on a soft key. It has to be in there somewhere.
Posted on Oct 05, 2009
Change the time zone to CST - it is stuck on GMT
Go into your settings, system date & time. Ensure the Automatic date and time is checked, along with Automatic time zone.
You can also make adjustments to time and date formats.
Back out, and restart your tablet to see if this works.
Date\time is a software function. Check to make sure you have the latest software version uploaded.
Mar 03, 2015 | ZEEPAD 7 inch Android 2.2 Tablet
Set date time
Typically on some of the Coolpix cameras there is an internal chip that holds the time and date. If it is no longer under warranty, it would cost too much to repair unless you can do it yourself. Nikon, though slow, will repair it if it is under warranty I am told.
Sep 09, 2013 | Nikon COOLPIX S710 Digital Camera
How to hide time on to display on nokia 2690
Hello there,
To hide the times display on the nokia 2690, simply go to the menu, select the settings, then you scroll to date and time, in date and time scroll to date and time format settings, in the date and time format settings select time, when you open the page you will see clock and 12-hours or 24 hours depending on what time format you are using, select clock, you will see show time and hide time, select hide time.
All the best Elect_Comp
Sep 15, 2011 | Nokia 2690 Cell Phone
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
Setting up date and time
Please check the date display format
In your mobile it might have set to this format
MM DD YYYY
So as the first column is in months as you enter 24 it doesnt accept and shows 02 ,This is because you have only 12 months in a year.
So please type month date and year.
If you want you can change the format to DD MM YYYY in date and time setting option.
Thanx
Thanx
Jul 24, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
MY DESKTOP TIME IS IN 24 HR FORMAT
START->CONTROL PANEL->DATE,TIME,LANGUAGE.....->Change format of numbers,dates and time. Under regional and language option click customize option and select time tab under customize regional options . There would be an option to change date, time change format. Click that and it would fix the issue.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 02, 2009 | Computers & Internet
Setting Date And Time
By Settings/Time and Date switch Time zone updating to Manual Only. Now you can set time and date below
May 31, 2009 | Samsung S8300 Ultra Touch platinium-red...
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 | Cell Phones
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Cell Phones Logo
16 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
