Question about Electrical Supplies
Homelite Lightnin Bug Generator not getting gas
Checked line to carb and it is getting gas. Runs great for 2 seconds when spraying starting fluid in spark plug hole.
    President:
  • 1,922 Answers
Try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
Posted on Oct 07, 2009
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
I spray carb fluid into the air intake and it runs. As soon as I stop spraying the carb fluid it stops running?
Hi, Making sure the gas is turned on,
Well the engine is not getting gas. If you have old gas in the unit the gas may have "jelled". A emptying of the tank and cleaning of the fuel line along with taking the bowl off the carburetor and spraying upwards into the carburetor, including around the float and needle and seat, may work. As always the carb cleaner is flammable so caution is good. Luck to you.
Jan 28, 2010 | Briggs & Stratton Power Products 5,550...
My 6250 generator has been dormant for a few years. Worked well previously. Can't start it now. It will fire with stater fluid, but stall. Fuel line checked and ok. I think Carb. might have buildup that...
yes gas will deteriate and leave varnish deposits clogging carberator and layer in tank has yellowish color flush lines with brake cleaner and spray carb with spray carb cleaner and spray inside fuel inlet on carb let sit about 15 minutes redo and sit about 4 times clean fuel tank with brake cleaner (with tank off) until clean, refill with fresh gas and add about table spoon carb cleaner per quart of gas and let in run for awhile. when storing for any period of time add fuel stabilizer to avoid this issue in future
Jul 07, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
Homelite string trimmer - gas
put it in the trash and buy yourself a new one nto the same brand.
Aug 09, 2008 | Electrical Supplies
Electrical Supplies Logo
326 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
