Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
When I push button to turn on, the light flashes orange. Nothing happens, no fan, nothing. It worked fine yesterday.
  • 657 Answers
It cannot be imagined what exactly may be the issue with your system. Still you can follow instructions on this service manual for this model.
It will be more helpful if you provide the details of Diagnostic LEDs on your system. Diagnostic LEDs are 4 LED numbered as 1 2 3 4 and indicate the kind of error as per their on of sequence.
Posted on Oct 05, 2009
  • 979 Answers
Good day sir/maam, the reason why its flashing orange is that there is no stable power, this could be caused by the following, so check each one out.
  1. Bad power supply, to test if your power supply, remove the 20 or 24 pin molex connector to your motherboard, locate the green wire, get a piece of wire about 4 inches and short the green wire with the black wire (any black wire) plug in your computer, you should see the fan spin. if not replace your power supply. If the power supply fan spins, remove the jumper wire, unplug your pc, reconnect the molex 20/24 pin on the motherboard. (check you mains if 110v or 220v, if its 220v plug on a 110v would yield the same symptoms as you described).
  2. Bad memory module, the memory modules are the thin flat boards near the processor, remove the memory module by releasing the side clamp, clean its contact plate with an eraser. then replace it. Test again. do it several times.
  3. (optional, if applicable) Bad video/graphics card, you may hear 1 long and 3 short beep. if this happens replace your graphics card.
feel free to inquire further, let me know your progress. thanks
    Scholar:
  • 82 Answers
This usually means a failed power supply and/or failed system board. No way to know further without swapping parts. Power supply is cheaper to replace .
2001 Subaru outback limited security light flashing rapidly!!?
Reset the system by removing both battery terminals
Hold the positive and negative together for 30 seconds
The. Reinstall both terminals
The system will re learn for the next 10 miles or so
If it happens again to the light
We will have to try another approach
Best of luck
Feb 22, 2015 | 2001 Subaru Outback
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on....
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Mar 13, 2011 | Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
May 08, 2009 | Dell Vostro 1500 Notebook
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Printer doesn't like new cartridge
It means you need to replace the photoconductor kit (the bit the toner fits into)
To reset this error, open the front door then press the cancel button for 3 seconds - all lights will cycle, close the front cover. The counter is now reset
Sep 02, 2008 | Lexmark E240 Laser Printer
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
