Home | Ryobi | Multi-Volt Battery Charger | 110 drill was plu...
Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
110 drill was plugged into 220 outlet
By mally_peter on Oct 05, 2009
can i fix it.
Solution #1
posted on Oct 05, 2009
Not Rated)
milleraba
Rank: Wiz  Tools - Building & Power  Expert
Rating: 83%, 447 votes
How did this happen? Did you jimmy the plug???
There is the possibility there is a fuse inside. If so, it blew when you plugged the charger in.
If not, you probably smoked it.
It may be better to replace it.
Was this helpful?
Yes
No
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
both green and yellow light stay on and batteries will not charge 18v
Answer
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a... (More)
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
Both green and yellow lights come on and stay on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi Multi-Volt Battery...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
