Unit in heating mode only electric heaters run no heat pump, also when in cooling mode unit does not run, Power is on.
  • 358 Answers
I understand that you have a heat pump that doesn't work in cooling mode , and if the thermostat is not for heat pump , it will not work.First be sure you have the right thermostat and then that is wired correctly. Let me know what kind you have and I help you to wire it.
Posted on Oct 06, 2009
Replaced Thermostat and now Blower Motor will not run
Sounds like a set up issue on the tstat. You say this is a packaged unit, inside the machine you should find where the tstat wires hook up. Typically red is power yellow is compressor orange is reversing valve white is emergency heat green is blower. Put red and green together, test blower. Then red green and yellow, make sure blower works again. If blower runs both ways it's either the tstat wire or tstat itself. Make sure you are landing wires on dedicated heat pump terminals, make sure in settings you are set up for heat pump with back up electric heat and TSTAT CONTROLS THE FAN. Good Luck. Also if there is a switch on the tstat for gas or electric on the back you want electric.
May 12, 2017 | Heating & Cooling
Amana #PTC153b50AJ ser 0410686783 Customer heard a pop in unit and it went off. Breaker was tripped. Reset breaker and unit runs in a/c mode but does not heat in heat mode. This is not a heat pump but...
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
Jun 04, 2017 | Amana PTC153B50AJ Electric Heat Air...
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
Sometimes the auxilary heat light comes on, and this morning the auxilary and emergency lights were on. Our electric bill has been really high the past two months.
Assuming we are talking about a Heat Pump system with an outdoor condensing unit and an indoor air handler, it is not uncommon for electric bills to escalate during the harder winter months.
Typically, the auxilary heat light energizes whenever the electric strip heaters are in use. These heaters are used to supplement the heat from your heat pump system which will be unable to maintain desired occupied setpoint with outdoor temperatures below 35degF. At outdoor temperatures below 35degF is not uncommon for the heat pump to run non-stop and the electric heaters will cycle on and off as the temp in the house drops between 1/2 to 1 1/2degF below setpoint. The electric heaters will also come on when the system goes into a defrost mode...defrost modes typically last anywhere between 2 - 8 minutes. The emergency lights, depending on your thermostat, will come on whenever the thermostat is placed in EMER HT. Some systems energize the emergency heat lights to indicate there is a problem with your condensor unit.
I suggest you ensure the thermostat is in HEAT mode and not EMER HT mode. Also, while the system is running, step outside and visually inspect your condensing unit. Is it running? Does it appear and sound like it is running normally?
Don't forget your air filter. This is the single most important and most-neglected maintenance item on your system.
If after these steps, you still feel as though you are having problems and would like to try and correct them yourself, please let us know.
I hope you find this information helpful. Good Luck to you! :-)
Feb 26, 2010 | Weather King Heating & Cooling
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
Duo therm roof air is stuck in the heat pump mode, it won,t cool
The control circuit board that controls the contactor for that unit is proboly damaged
If it is a heat pump. And not electric heat
Or the Yellow wire from the thermostat going to the unit that wont work in thecooling mode is broken,burned,or loose
May 26, 2009 | Heating & Cooling
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
