Question about Pool & Spa
Pump is making loud noise and is not pumping properly (strong)
Check for leaks . Sounds like it may be picking up air
Posted on Mar 09, 2010
  • 8,404 Answers
Remove the pump, I think you will have a damaged impeller or something stuck in the chamber.
I once found a dime in the chamber that made a $1.00 worth of racket!
I hope this helps you
a
Posted on Oct 05, 2009
My car keep on breaks alternator belts and it also makes this loud whistling noise. I've put on a new water pump, 3 alternators and several alternator belts
make sure that the pulleys of all the driven equipment are in alignment and not at a bit of an angle to the axis of the drive belt
To break belts something is not lined up properly or something is not turning freely
Dec 31, 2015 | 2000 Mazda Protege
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
Fuel pump noise 2005 Buell xb9sx
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
Apr 14, 2010 | 2005 Buell Lightning CityX XB9SX
Pump makes noise and water runs out of bottom of machine error ob
HI. You may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case, replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
A broken impeller will wobble inside the pump housing, causing loud noises during operation. This is a strong indicator of pump failure. This will, also, cause leakage as well. the integrity of the pump housing will be compromised, leading to this leakage.
Sep 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Powersteering stopped working
hi there, there are some things that u need to check, one is power steering fluid in the resovoir, is the system leaking, is the belt in good condition, do you hear a loud noise coming from the pump when the vehicle is running and you turn the wheel hard in both direction
Jul 21, 2009 | 2004 Ford F150
When running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
Jenn air dishwasher- making loud noise in operating cycle
Hi I am Vortash by the sound of what you are descibing your pump bearings seem to be shot , although it is making this sound is it still washing properly if so it confirms it is the bearing and not the impeller catching and making the noise the pump gets to quite a high pressure to wash the dishes .. sort of an enclosed hot jet wash the force of which drives the spray arms .. so I am afraid it looks like you will soon need a replacement pump.. sorry to bare bad news .. Regards Vortash
May 22, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Pool & Spa Logo
228 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
