Question about Brother MFC 240C All-In-One InkJet Printer
Can not get my black ink to print. color works fine but black not working at all.
Mix-it-up
  • 832 Answers
SOURCE: Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Posted on Sep 11, 2007
  • 320 Answers
SOURCE: replace black ink in brother mfc-465 inkjet & now it won't print
are you using brother oem ink? you ,may check and see if the seal is still on the cartridge, if not try and take a paper clip and insert it in to the air hole on the catridge, some times it gets clogged up. brother tech
Posted on Jan 13, 2009
  • 116 Answers
SOURCE: Black ink not printing
replace print head assembly
Posted on Aug 02, 2009
KingDWS
  • 1606 Answers
SOURCE: MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Posted on Aug 17, 2009
  • 5 Answers
SOURCE: MFC 790cw will not print in black.
garetg,
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Much Regards,
Kyle
Posted on Sep 16, 2009
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Eson 740 will no longer print black ink
May I know if the printer is working on any computer.
It assume to be the Black Ink Head of the Printer is decayed. I mean to say the Surface where the Ink cartridge contacted to Printer, the film also need to be replaced. Plz check it to nearby service centre.
Apr 15, 2009 | Epson Stylus Color 740 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
A960 All in One Printer not working with color cartridge
My new black ink cartridge wasn't working at all. I sprayed the cartridge with windex and let soak for a minute. I wiped dry with paper towel and there was black ink on my towel unlike before. The windex unclogged it and it worked like new!
Oct 17, 2008 | Dell A960 All-In-One InkJet Printer
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Brother MFC 240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
