Western Digital 500GB My Book World Edition 500 GB Hard Drive
Problem for Western Digital 500GB My Book World Edition 500 GB Hard...
My 500g Western Digital MyBook is hissing and is
By wet9855 on Oct 05, 2009
My 500g Wetern Digital MyBook is hissing and is not being recognized by mutliple computers.
Solution #1
posted on Oct 05, 2009
Somewhat Helpful)
AlliedSOS
Rank: Guru
Rating: 91%, 27 votes
this is almost certainly a bad drive. If it's using a usb cable to connect, verify the cable itself has not gone bad by swapping out with a known good one. If that doesn't help, it sounds like time for a new drive, sorry.
Was this helpful?
Yes
No
Solution #2
Not Rated)
bob_computer
Rank: Guru  Western Digital Computer Accessories  Expert
Rating: 87%, 1255 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Was this helpful?
Yes
No
Popular Solutions for Western Digital 500GB My Book
Questions and Unsolved Problems for Western Digital 500GB My Book
Do you recommend Western Digital 500GB My Book World Edition 500 GB Hard Drive?
Answer
Answer
very slow to open files, several do not open. does not allow deletion of files, all files affected... (More)
Answer
I have a WD 500GB My Book World Edition and only need to use it for back up...problem: I've hooked... (More)
Answer
win7/ WB5000ME drivers? I cannot access the disk or format it but Vista seems to have no problems?
Answer
For the most part, South America became a collection of independent states between:
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
