Question about Compaq Presario F730US Notebook
My Compaq Presario F730US keeps overheating the fan does not run properly what docking station do you recommend me to buy
  • 1 more comment
  • ulyssemc1 Oct 19, 2009
    The Fan works sometimes if I tap it then it gets stuck
    Thank you for the tip about the thermal compound every 6 months I think that will solve the problem completely
  • Taniela Matai
    Taniela Matai May 11, 2010
    does the fan work when you boots up your laptop.....overheating can also be caused if the environment u're working on is not conditioned enough
    President:
  • 2,600 Answers
I would recommend cleaning out the vents and geatsink grills with compressed air. I would then remove the heatsink unnit and replace the thermal grease on the heatsink and processor. Most laptops do not need any additional cooling if thier heatsinks are free of dirt, dust and debris. The compressed air can be bought at office supply chains. Just use short bursts of air and clean all the compartments including the cd tray. Just make sure to power down the laptop first and remove the battery.
Posted on Oct 06, 2009
Testimonial: "I replaced my fan and it cools down now but I did not put the thermal compound on and my laptop spins the fan at an extremely fast rate until it shuts"
  • Chip
    Chip Oct 19, 2009
    When your fans "spools" up like that it means the processor's algorithym is telling the fan the the processor is hot and needs extra speed to cool it down and then shut off. I advise customers who use their laptops regularly to replace the thermal compound evry 6 months. It is cheap insurance.
    Here is an illustrated disassembly guide.....
    http://www.insidemylaptop.com/disassembl...
  • Chip
    Chip Oct 19, 2009
    You are very welcome......
I took my Compaq Presario laptop apart and I found that there was no heat transfer grease between the heat sink plate and the CPU?! There is a sensor built into the heat sink plate that controls fan speed and I believe that without the grease the sensor was not reading the correct temperature to regulate fan speed during cooling thus the constant lockups (CPU going into thermal shutdown). Make sure the spring-loaded screws are tightened down as well for good contact between the CPU and the heat sink plate. They should be indicated with numbers 1-4 on many Compaq laptops. Afterward, I ran several CPU tests and no more lock ups. This grease can be bought at any good computer store but use just enough to cover the chip and not too thick. I would only recommend this to someone who knows how to work on computers. Good luck!
Posted on May 17, 2010
I forgot my administrator password for my compaq presario f730us
have you changed admin password recently ? if yes and if you remember the old admin password, you should go ahead and restore the laptop to it's previous point when new password was not set.
restart the notebook and keep tapping f11 key until Recovery manager window appears.
under I need help immediately, select Microsoft System Restore
click next
in Vista, you will find System Restore under Advance option.
Aug 03, 2011 | HP Compaq Presario F730US Notebook
I think my compaq presario f730US notebook pc has a built in micophone but i'm not sure does it?
Compaq presario f730US notebook doesn't have an inbuilt microphone. It employs a connector (port - 3.5mm jack) to connect an external microphone.
reference : link1-cnetreview
link2-compaq
link3-Buy.com
Oct 29, 2009 | HP Compaq Presario V6000T Notebook PC
Is there a docking station that is compatible with this computer? I am considering adding a new monitor & wireless keyboard
You can get a HP COMPAQ dock for your what ever model HP Compaq Presario laptop you have or you can also get a universal dock that will work as well. Kensington, Targus, etc.
Jul 19, 2009 | HP Compaq Presario V5101US Notebook
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
Laptop will not start
It's possible the video card is burnt out from over heating.If it is you need a new motherboard.
Jun 01, 2009 | HP Compaq Presario F730US Notebook
Compaq Presario F700 keeps turning on and off
At this point I assume you've tried to go into SAFE mode, and into BIOS with no luck. You're right about the overheating but I think the damage is done. If the unit will no longer stay on in any mode or condition then heat has ruined something. First easiest part to check is memory. The check the CPU (most laptops still have a plug in CPU). If neither of these are suspect then take everything off the motherboard, including the screen (I use and external monitor). If the problem still exists then it's time to use a scope.
May 30, 2009 | HP Compaq Presario F730US Notebook
How do I remove and replace keyboard on compaq presario f730us?
Here is Compaq Presario F700 series manual.
Scroll to page 52 for keyboard removal.
Mar 28, 2009 | Compaq Presario F730US PC Notebook
Setup to my laptop docking station
Docking station Most docking stations allow a user to connect their laptop computer to a docking station and get the added support of other peripherals such as other drives.
Good Luck, Please dont for get to Vote/Thank You.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario F730US Notebook Logo
655 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
