Question about Whirlpool Dryers
I have a dryer,that after it has been running for a few minutes, you can start to hear this clicking in the back, and then dryer quits heating.
  • Whirlpool Master
  • 3,361 Answers
Clean out the internal and external exhaust vent. The lint is causing the problem. Also,check the blower wheel attached to the motor. Make sure the wheel spline is not stripped out.
Posted on Oct 05, 2009
DRYER RUNS SOMETIMES MID CYCLE DRUM QUITS TURNING BUT STILL HEATS UP COMES BACK ON AFTER A FEW MINUTES
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 26, 2011 | GE Dryers
Dryer heats up for a few minutes and then quits but dryer still runs
Hello
When the dryer heats for few minutes and then it won't work it means that the thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this fuse for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Speed Queen AES28AWF Electric Dryer
I start time dry for 60 mins. It will run for
The heater element is not heating, they are fragile easy to get to at the back of the dryer. Check the thermal or overheat switch too, but would bet its the heater element.
Nov 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
Mar 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Feb 21, 2008 | Kenmore 62602 Electric Dryer
Quits heating
I would sugest you to replace the coil of the selenoids, after they get old, they dont work properly
Dec 14, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
29 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
