Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stops and flashes H and F - Whirlpool Duet GHW9150P Front Load Washer
  • 6,784 Answers
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.(likely the pressure switch or hose)
Posted on Oct 05, 2009
Washer stopped in mid wash. Clean light came on and flashes 7 times. Pressed clear went to 2 and finished. Pressed start light flashed 3 times won't start.
remove the bottom kick panel,you'll see a tech sheet there in the plastic bag,it will tell you how to check to see if the heater or board is bad,the light will flash 7 times,it's an error code telling you that there's a heat problem.
Feb 20, 2015 | Dishwashers
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
Apr 05, 2014 | Hotpoint WMA58 Front Load Washer
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Stops and flashes H F on digital display
The reason for the H/F error codes is a bad water valve in your washer.
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00 .
Thank You for contacting Fixya.com
Aug 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Service m6500 after last wash the start button contiues to flash unable to use washer even if power is turned of
My washer did the same until i relalised that after the wash when light is flashing, turn control to stop position and wait until it stops flashing before turning machine off. Sometimes i have to turn control right around again for it to stop flashing but this is how it works.
Dec 07, 2008 | Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
