Question about Cameras
Need software to run my mx500 for windows xp - Cameras
Need software FOR MY USING WINDOWS WINDOWS 7?
Hi
I presume you are referring to the disk for an mp3 player as in the question category being for Windows XP and you are using Windows 7 on the computer you want the player on. Generally the easiest way to do this is go to the author', publisher's website and get an updated version of the software that will run on Win 7.
Alternatively you could try running the software installer and subsequently the software itself under Windows compatibility for XP. Right click on the files and select and click on "troubleshoot compatibility" and follow instructions.
A second option is to create a Virtual Machne within Win7 and run Windows XP on this machine which will behave exactly as Win XP. This a complex procedure and you need to have a valid copy of XP as well as your Win7.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 28, 2014 | Audio Players & Recorders
Changing from windows XP to Vista
If you are talking about Bernina artlink software here is a patch, but you nbeed to register. Check it out
Feb 25, 2008 | Bernina Artista 180
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
The installation says that is not compatible with my windows 7
The software is very old, so old that it doesn't run any compatibility modes for windows 7. You need to either run it on windows xp, or use something like virtual box to run it through xp.
Jul 02, 2011 | Global Star Software Army Men: Sarge's War...
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
How can I use my Cakewalk plasma 2003 software om my new windows 7 computer?
As you know Plasma runs on Windows 98/Me/2000/XP. I don't have any specific knowledge of Plasma 2003 but if it needs specific drivers you are probably screwed since there is no Vista support listed.
Win7 has the capability of running XP Virtual machine (available on Windows 7 Professional and Windows 7 Ultimate, allows you to run multiple Windows environments, such as Windows XP Mode, from your Windows 7 desktop). It slows the software down and may not be good for Plasma. I've used it for some old software.
I did a lot of searching and could not find specifics to your question. I take it from your question it is not working.
Jan 05, 2011 | Cakewalk Plasma 2003
I am running Windows XP as a virtual PC under windows 7. I find that Mathcad 11 will not install. It will install directly under windows 7 but will not run. Mathcad 11 did run just fine under XP but...
The software don,t support Win 7.See this chart form portal:
Platform Support Platform Version Supported CPU ODBC Driver Support
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
32-bit
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
Dec 20, 2010 | Mathsoft Mathcad 11 Full Version for PC
Have a logitech mx500, can not get windows 7 to let me set button functions, mouse shows up as hic compliant....ect, but picture and button are for 2 button mouse
Hop online, and chase down a driver for the mx500 (logitech should still have one on their website). Try to ensure that it is windows 7 compliant.
Install the driver and your problems should be solved
Hope this helps, Sherwin
Jan 11, 2010 | Logitech (9311730403) Mouse
Mac Driver for Panasonic NV-MX500
I have a NV-MX500 and I need to connect to a PC to play do i need to capture video in windows movies maker
Dec 15, 2009 | Panasonic NV-MX500B Mini DV Digital...
Problem with Windows XP
as you installed another windows into your computer, you will need to install all the software again, and the emails need to be imported from the old location to the new location.
Aug 22, 2008 | Computers & Internet
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
