Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer won't align cartridges after replacing new ink cartridge
I'm having problems after putting in a new color ink cartridge. I can't get it to run the align cartridge function. It starts to print a page and only prints something at the top of the page and then says it failed and to try it again. I've tried many times and it continues to fail even after power down and re-booting the system. Any suggestions?Sandi
  • 57 Answers
SOURCE: cartridge alignment
I understand that you are receiving the message to align print cartridges when ever you print.
This happens due to various of reasons.
Below are the possible causes of the issue that you are experiencing with.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
So, make sure that ink cartridges have sufficient amount of ink and are of genuine HP should not be refilled or remanufactured.
Clean the cartridges by following the below given instructions:
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Align the print cartridges by following below given instrucions:
To align the cartridges from All-in-One
1. Press Setup.
2. Press 5, then press 2. This selects the Maintenance menu, then selects the Align Print Cartridge option. A page prints to confirm alignment. You can either discard or recycle this page.
Even if the issue persists, bypass the alignment by following the below given instructions:
Press Enter and Setup simultaneously when align message is prompted on the All-in-One.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
This should resolve the issue.
Regards,
Lawrence
Posted on Jan 12, 2008
SOURCE: Ink cartridge alignment problem
I tried to clean & realign but it stills shows an error. HP is no help. I guess you need to align every time until you run out of ink & get a new cartridge. Why won't HP admit a problem & replace the cartridges?
Posted on Mar 25, 2008
SOURCE: Alignment fails when i press
Press Enter then Setup you should be good.
Posted on Oct 10, 2008
SOURCE: cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Posted on Oct 29, 2008
mdsaeed67
  • 849 Answers
SOURCE: Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Posted on Nov 29, 2008
The colour ink cartridge is not being identified. I have tried taking them out and putting them in again. I have powered it off and on but nothing is working. Any suggestions would be greatly appreciated
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Jan 09, 2011 | Dell 924 All-in-One InkJet Printer
I have put a new black cartridge in printer but nothing is printing out- when I run a test the color cartirdge are working but not black
Hmmm, make sure it is properly fitting in there.... Take it out and put it back in.... Usually the printer performs some kind of "preparing the ink" operation... SO allow it to does this...... Make sure you are using genuine ink, sometimes printers won't accept non-genuine inks.... Hope this helps :)
Jan 08, 2011 | Brother MFC 490cw Color Inkjet...
Just replaced both ink cartridges and test pages have color bars in middle of page and columns are not aligned.
hi there !
-if you have replaced the ink cartridges and you have the color bars in middle of page and columns are not aligned, try to do the alignment of the ink cartridge
-if the alignment procedure fails; try the old cartridge
-if the old cartridge exhibit the same problem, you need to replace the printer
Oct 24, 2009 | Dell Photo 964 All-In-One InkJet Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Printer will not except new color ink cartridge
protocol for cartridge replacement
take out old one..recycle
install new cartridge
clean heads and re align them
print test page
see how it runs..
check your computer warranty here for FREE
Feb 25, 2008 | Dell 922 All-In-One InkJet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
288 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
