Question about RCA DRC8300N DVD Recorder/VCR
Dvd door will not stay shut when dvd is loaded. i've blown into it hoping it may have dust inside but it won't stay shut unless there's no dvd in the drawer.
    Genius:
  • RCA Master
  • 1,550 Answers
Check if the trayer got a belt and change it ,is located under the tray
Posted on Oct 06, 2009
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Won't stay on
You're best bet would be to buy compressed air and blow out all dust and dirt that has made its way inside the receiver. If dust is clogging the fans it will overhead and shut itself off.
Mar 14, 2013 | Yamaha Natural Sound Htr-5660 6.1 Channel...
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
Feb 19, 2012 | Panasonic DMR-ES40V DVD-Video Recorder
The door that holds the batteries in will not stay shut i believe maybe where you slide it shut a piece of that might be broken is there anyway to fix that or do i just need to hold it closed and hope for...
Pull the batteries out and see if it will stay closed, if it does the batteries are installed incorrectly. If it still won't stay closed your options are to either tape it shut or get a new camera unless it is under manufacture warrenty still or you have an accidental damage plan.
Jul 28, 2011 | Olympus FE-210 Digital Camera
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
RCA DRC8300N DVD Recorder/VCR Logo
147 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
