Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Replacing traction drive belt for John Deere L118. Is this a do it yourself similar to mower deck belt? No instructions in operators manual for traction belt. Are there instructions on line rather than buying service manua?
  • 389 Answers
Actually this is a fairly easy looking one to replace. If you go to John Deere parts and do a search for your tractor, in the parts listing it gives a pretty clear picture of the routing and configuration of the belt as it should go on, you might want to print it out to have nearby while you are working on it. You will need to remove the mowing deck to get at it and possibly some large blocks to elevate the tractor to give yourself room to work.
Look closely at the old belt if it is still on the tractor to get an idea what is involved BEFORE you start, comparing it with the picture. You will need to loosen and move or remove the belt guards and do be careful of the nylon fan on top of your transaxle
Posted on Oct 11, 2009
What is the configuration of the mower deck belt on a john deere 42 inch mower deck model L118
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere L110 Lawn Tractor Service Repair Manual
Feb 25, 2017 | John Deere Garden
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
How do I replace the drive belt on a john deere 265? There doesn't seem to be a clear answer anywhere. Please help
you can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Aug 03, 2014 | John Deere Service Repair Manual 240 260...
John deere l118 belt adjustment
There are two things to check first. First is that you have the right belt on there and it is not worn. Second would be that all the springs are on the proper tensioning pulleys under the deck. After that then you need to look for an adjustable pulley that is manually tightened and held in place by a bolt. That will be your idler. You will also want to check the track of the belt to make sure nothing is bent.
May 15, 2012 | John Deere Garden
John deere x300 will not move
It sounds to me like the traction drive belt slipped off of a pulley or broke. The easiest way to get to the traction belt is to remove the mower deck. There is no easy way to replace the belt, however. It runs from the transaxle at the rear to the engine at the front, around idlers. Let me know if you would like assistance in replacing the belt and I can walk you through it, Daniel.
Oct 07, 2011 | John Deere 22HP Hydrostatic 42" Riding...
I need a belt diagram of the mower deck for a john deere L118
Here is a link for your manual. http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO If you need more info please contact me. Thank you
If you have time please rate my service by giving me 4 thumbs up. Some people give testimonials. Thank you
Jul 11, 2011 | John Deere Garden
My L118 John Deere Lawn mower doesn't want to go up hills or even move after it gets hot. what is the problem?
check drive belt tension when m/c is off.remember OFF! if too loose,refer to manual.
Jul 21, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
3,658 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
