Kenmore 30464 / 30465 / 30469 Gas Single Oven
Problem for Kenmore 30464 / 30465 / 30469 Gas Single Oven
My Kenmore gas oven does not light.
By hilaryjgerla on Oct 05, 2009
My Kenmore gas oven does not heat. The burners work fine. The oven worked on Saturday and Sunday it didn't. It has an electrical ignition switch. Does that break and would it be an easy fix? Any suggestions? Thanks! (model 362.75371690)
Best Solution
posted on Oct 05, 2009
Helpful)
jumptrout51
Rank: Guru  Kenmore Ovens & Ranges  Expert
Rating: 89%, 1005 votes
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 01, 2009
Not Rated)
cornerstonet
Rank: Apprentice  Ovens & Ranges  Expert
Rating: 0%, 0 votes
oven is on celsius, not ferenhiat
Was this helpful?
Yes
No
Popular Solutions for Kenmore 30464 / 30465 / 30469
Questions and Unsolved Problems for Kenmore 30464 / 30465 / 30469
Do you recommend Kenmore 30464 / 30465 / 30469 Gas Single Oven?
Answer
Answer
broil and bake no glow at coil only 50 volts at hsi wires
Answer
my 2001 gas stove's oven will not light it did this morning but stopped while i was using it could... (More)
Answer
oven doesnt light- ignition clicks but doesnt light
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 30464 / 30465 / 30469...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1200
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
