Question about Lexmark X83 All-In-One InkJet Printer
Paper will not feed thru the printer. - Lexmark X83 All-In-One InkJet Printer
SOURCE: lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Posted on Oct 26, 2008
gwbm
  • 353 Answers
SOURCE: Epson stylus C66 doesn't print
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Posted on Mar 09, 2009
  • 14 Answers
SOURCE: paper wont feed thru the printer
hi!! in that kind case my troubleshoot of that is the feed mechanism was defective and try to bring that in your nearest lexmark service center.
Posted on May 18, 2009
Ajkill
  • 2035 Answers
SOURCE: the paper wont feed thru the printer. What is the
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2009
SOURCE: LEXMARK X5450 PRINTER--PAPER WILL NOT FEED INTO PRINTER
i need a solution to get out of my lexmark x5450
Posted on Jun 09, 2010
Paper will not feed thru my Samsung ML-1210 Printer. How do I fix?
Check to see if you have dropped something in the feed... maybe a pencil, paper clip, some pizza...
Feb 21, 2015 | Samsung Office Equipment & Supplies
The top feed isn't working for faxing and scanning
The first check is to see if the left rear hinge assembly is broken, it keeps the lid lifted so it won't feed. Otherwise you need to check for any paper clips or scraps in the paper path area, you need to use a flashlight and look both down thru the top and also up thru the bottom where the paper passes thru.
Dec 18, 2009 | Brother MFC-8460N All-In-One Printer
Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark X85 Printer
Jul 23, 2008 | Lexmark X85 All-In-One InkJet Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Lexmark X83 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
