Question about Dell XPS 700 PC Desktop
My 700 will turn on sometimes an it sometimes won't then flashes amber i read that i should replace my power supp i took the side cover off but i dont see how to get it out there are 4 screws on back but there no room to work it out of cabinet an i dont know how to take off top please help...
  • chriswojr
    chriswojr Oct 14, 2009
    i replaced the power sup and it turns on but its not finding the boot file an the hard drive clicks a couple times any ideas ???
  • 21 Answers
Ok the 4 screws on the back are easy but i think what your talking about is the processer heatsink and things of that sort all that can go in and out easily ,the memory chips just find the tabs on the side of them and gently push them outward and the memory should pop out.but when putting them back in use both hands and make sure the slots line up on the meory and the board, now the processer is hard to say im not sure what style processer heatsink you have that has to be removed ,but you can hook a volt tester to your main power supply plug to see if its putting out what its supposed to be if not you know thats your problem
hope this help,
will
Posted on Oct 05, 2009
Testimonial: "thanks"
  • 3,940 Answers
  • IQUIT Oct 14, 2009
    Ahh, the soul wrenching sound of the hard disk drive "Click of Death". Try booting to your Windows CD and go to R for recovery console. See if you can run CHKDSK /R and you might be able to get back into windows. But most likely, you are replacing the hard disk drive
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Power bottom light flashes amber and the temperature light is steady amber after DMD chip replacement.
Sounds like a board problem or a bad temp sensor. Those things get pretty hot (charred) and you may have open circuit it when you swapped. Did you put the old one back in?
Nov 25, 2014 | Dell 4610X Wireless Dlp Multimedia...
Amber light is flashing on my computer and it won't turn on at all. Help!
The Dell Dimension 300 gets the amber blinking light when there is power to the computer (the power supply) but the motherboard isn't getting the correct power. Sometimes it can indicate a motherboard fault or that the power supply is not set to the correct incoming voltage.
Check the back of the computer. If the power supply has a switch for incoming voltage, make sure that it matches your incoming voltage. Next check that the main power cable (20 or 24 pins depending on the computer) is fully seated on the motherboard. (It can only be connected one way and should lock onto the connector on the motherboard.)
Next check that the power supply is providing the correct power. You can simply install another power supply (known to work on another computer). Make sure that the PSU is correctly sized for the computer components. Alternatively use a multimeter or a dedicated power supply tester or put it in a different machine.
If the problem is not cured with a new PSU, the motherboard has a failure. Unfortunately, it's difficult to identify the exact bad component. (If a major component other than the CPU on the motherboard had failed, the diagnostic lights or beep codes could help identify the issue.)
I hope this helps.
Jun 10, 2012 | Dell Dimension 3000 PC Desktop
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Tape won't eject
Soft power the unit down and very carefully unscrew the cover. The greatest care must be when taking the tape out so that you don't bend the unit.
Consider blowing it out to get rid of dust and it very likely has a problem that will require service. My quantum px502 had a stuck tape and I took the cover off but the picker was already off track - $700 to fix that and replace a sensor.
Consider a maintenance contract as on visit to the repair shop will cost hundreds of dollars.  And, if you get the tape out another will likely stick soon.  So service will be necessary.
Jan 08, 2010 | Dell PowerVault 114T (0CC011) LTO-3 Tape...
DELL XPS 700 AMBER LIGHT
you don't tell us from where coming the amber light from the cpu or from the monitor?
May 29, 2009 | Dell XPS 700 PC Desktop
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
LG 211cm rear projection RT-48SZ40RB
the amber ight is a simple warm up procedure as it projection seems a power problem...
Aug 01, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Dell XPS 700 PC Desktop Logo
269 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
