Question about DVD & Blu-Ray Players
Portable dvd player says loading but won't do anyting
My portable dvd player spins the disk and say loading but won't do anything after that
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
  • 752 Answers
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Posted on Sep 23, 2007
  • 979 Answers
For whatever reason, the laser assembly is not able to read the discs. This could be caused by any number of reasons including an alignment gone bad, to a dirty lens, to a bad laser diode...accordianman
Posted on Jul 07, 2008
SOURCE: durabrand portable dvd player motor spin but disk not playing
I have the same problem, the this dvd player i use one time
Posted on Dec 30, 2008
  • 146 Answers
SOURCE: audiovox d1708 portable dvd player: DVD spins and says loading...
If it does it with all discs then the player is dying. If it is just the one disc I would say it is a bad disc. You can also see if there is dirt or grease or fingerprints on the laser pickup lens.
Posted on Jan 01, 2009
  • 173 Answers
SOURCE: Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Posted on Feb 07, 2010
0 characters
1 Points
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
Unit stops spinning after loading & shows "no disk"
could be down to a dirty lens , faulty lens or faulty dvd player spindle motor.
Aug 05, 2009 | Amphion Mediaworks M-520 Portable DVD...
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
Disc won't load and then shows weird symbol in right corner
Check the black spindle that holds the disk it may be cracked or broken or the little spring tabs are broken. If this is the problem when the disk spins it lifts up and the head doesn't read the disk, this is what has happened to mine. I am trying to locate the part but so far have not had luck finding it.
Sep 17, 2007 | Audiovox D1708 Portable DVD Player
sounds like the laser doide has failed, and may not be practical to have repaired. D-Dan
Aug 25, 2007 | Coby TF-DVD7100 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
May 28, 2006 | Initial IDM-1210 Portable DVD Player
DVD & Blu-Ray Players Logo
155 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
